Sent PM..
Hellobox 8 firmware release 20210209A
Re: Hellobox 8 firmware release 20210209A
Hello Developer, please fix this error of skipping transponders when blind scanning on the next new firmware.
Discovered that too.. however,kind of believe the speed level of the blind scan is responsible because some tps take some second before establishing their presence.. hence if blindscan speed is reduced a little, then all tps can be captured
SCAM+ is not connecting still now from the release date 20210209. Look into the matter.
Please fix multistream at optus D1 160E sir! New sw can't watching if we have minim signal. But if use others receiver can in one stream 135 SBS. Thanks if u realization for it sir!!!!
You can continue this sw version for make new sw, cause i think will be good sir!
- Hellobox8_test_only_0823.zip
- sw fix version for multistream optus D1
- (4.35 MiB) Downloaded 476 times
I am only give sugestion, and next.....up to you sir! hehehehe
Freezing issue on scam plz fix it
and how to chek working satellite on scam ? any link
You're doing a good job. Keep it up
