About Hellobox 6605S ROM ...
cyberworld23
Re: About Hellobox 6605S ROM ...
Where can i download additional tool to import remote control buttons and front panel configuration ?
Ramizraja86
Please send your new update geo network
pritamcharan
Great work FreeDVB Team.
Can you Please Add Hindi language for menu and for preferred audio language
Lala
Oh dear how to add tend berg key any method please
OR
Soft key
OR
Soft key
https://www.mediafire.com/file/78qawtdj ... U.mp4/filecyberworld23 wrote: ↑Thu Dec 10, 2020 4:18 pmWhere can i download additional tool to import remote control buttons and front panel configuration ?
cyberworld23
Thanks u
erosman87
Dear Dvb Finder Moderator , please fix audio language selection issue that the firmware has . The dvb can't remember the xhanges , after we push audio button on remote control, and select other than English language after switching to another chanel it comes back to default English , because we don't have an optiin to change first and second audio language in menu settings . You can delete 3g modem , timmer settings or sleep support to free necessary space for second audio language and even put weather widget . If inly I could edit the COBFIG.bin default.xml with adding some Language lines and djcf.json with adding weather - the ussue is that CONFIG.bin can't save its real file size 9kb after changes are made filesize becomes 4kb
kuzown
I agree with this.erosman87 wrote: ↑Mon May 10, 2021 10:57 amDear Dvb Finder Moderator , please fix audio language selection issue that the firmware has . The dvb can't remember the xhanges , after we push audio button on remote control, and select other than English language after switching to another chanel it comes back to default English , because we don't have an optiin to change first and second audio language in menu settings . You can delete 3g modem , timmer settings or sleep support to free necessary space for second audio language and even put weather widget . If inly I could edit the COBFIG.bin default.xml with adding some Language lines and djcf.json with adding weather - the ussue is that CONFIG.bin can't save its real file size 9kb after changes are made filesize becomes 4kb
Is there a way to choose default audio/subtitles different than english?
Joshys
Hi,
I just purchased L- code for my receiver, I don't know how to get scrambled channels on Indian DTH channels. Someone please help.
