can't add m3u to hellobox 8
Hi Guys,
I just received my hellobox 8. I tried to add my m3u, following the instructions to create a file named mtb_list and past my m3u line to it and use a USB- but, it does not work. I get an error when I open Mytube or M3U Player. Also, it seems the receiver does not allow to download other apps, other than the existing ones. Could you help.
my m3u line is as below: (removed details)
http://line.ma-xxxxxx.com:80/get.php?us ... e=m3u_plus
Do I need to change the format on how?
Re: can't add m3u to hellobox 8
kensington wrote: ↑Sun Jul 26, 2020 7:06 amHi Guys,
M3U Player can download only simplified playlist in playlist.m3u format
# EXTM3U
#EXTINF: -1, channel name
http: // ......
https: // ......
Question to the moderators, what should be added to the list so that you can create a separate folder with the list of channels as LIVE
http://prnt.sc/toobx0
I am very disappointed to find out that Hellobox 8 is no good for anything. No option to download new apps and can not upload my m3u to the existing apps such Mytube, or M3u PLayer. I understood from the reply to my thread that Hellobox 8 can only upload a simple channel m3u rather than my IPTV group.
Can anyone please explain further whether I am wrong or right? Are you experiencing similar issues? I waited for this box to be delivered from China for 10 days and cost me £33. The box does not seem to be able to take on iptv or can make use of any apps.
can you please explain how to upload my IPTV (m3u, list of channels) to Hellobox. to date, I could not use any of existing apps to upload my m3u packages. I can not download any new apps. What is this hellobox for? can anyone share their experience or explain what could be wrong?
kensington wrote: ↑Mon Jul 27, 2020 7:02 pmcan you please explain how to upload my IPTV (m3u, list of channels) to Hellobox. to date, I could not use any of existing apps to upload my m3u packages. I can not download any new apps. What is this hellobox for? can anyone share their experience or explain what could be wrong?
1. Upload your playlist.m3u to a flash drive.
2. connect the flash drive to Hellobox 8
3. open the M3u PLayer applications (if M3u PLayer is open then press OK => red button)
4. A window will appear to select ... .m3u file
5. select the one ... .m3u from the list (the list you want to open if you have several) and press the yellow button.
6. the list will be loaded
7. watch IPTV channels.
The next time you open M3u PLayer, the list of IPTV channels will automatically load
I did this process but it did not work. I get an error. How do you upload the m3u list to the USB. what name do you use for the file. could you explain the process please. I must be doing something wrong
1. I downloaded the file mtb_list.
2. I copied and pasted my m3u line (http://line.XXXXXX80/get.php?usernameXX ... e=m3u_plus) into
the body of the mtb_list file.
3. I opened Mytube, clicked on right. I can see blue icon (USB upload). a number 1 appear, I click on it and take 3 seconds and then I got "play error"
Could any one please explain the process. what am doing wrong?
The file name is mtb_list.txtkensington wrote: ↑Mon Jul 27, 2020 10:08 pm1. I downloaded the file mtb_list.
The specific format is as follows:
ANTV
http://210.210.155.35/qwr9ew/s/s07/01.m3u8
BERITA
http://edge.linknetott.swiftserve.com/l ... ylist.m3u8
SATU
PS.Do not have a space in the program name, otherwise the name will be empty.
Not support https url.
- mtb_list.txt
- (231 Bytes) Downloaded 736 times
ANTV
BERITA
SATU
Could you please give me an example what I need to copy and past to make mtb_list file recognised by Hellobox 8 Mytube app?
Could you please convert details below, and write an example to what I need to write in mtb_list file.
do I need to stat with # EXTM3U.....or #EXTINF: -1, channel name? do I need to remove _plus from m3u line below?
I tried
#EXTINF: -1, IPTV
ttp://line.ma-nnnnn.com:80/get.php?use.......m3u_plus
I clicked on blue icon (USB Upload). I got 0001 IPTV folder in left side of Mytube. when I clicked on 0001 IPTV, I got an error "Play error" I also tried again by removing _plus and still same error
The detail of my IPTV provider are in the format below. I have removed username, password, and name of provider,
http://line.ma-nnnnn.com:80/get.php?use ... e=m3u_plus
Pass : vvvvvvvvv
If you use IPTV Smarter pro , URL : http://line.ffffff.com:80
I tried
#EXTINF: -1, IPTV
Pass : vvvvvvvvv
