Hellobox V5 firmware release 20191109A
maeswara
Re: Hellobox V5 firmware release 20191109A
Hi,good day
1- Can you provide step by step guide how to update new release firmware so newbie like me know what to do
2-Why cant just auto update through box itself,so new bie like me dont have to worry
tekmed
@gxu
Hello my friend,
I'm happy with this version, but I'd like to ask you please if some important update can be done.
WPS push button mode : I'm using a complex key, and can't write it through visual keyboard. Please is there any possibility to enable this feature ?
Youporn : I'd like to remove it completely, not just hiding avoiding bad surprises (Dump file in attachment)
Please can you help ?
Hello my friend,
- gxu
Sorry, I don't understand what's "WPS push button mode".tekmed wrote: ↑Sun Dec 08, 2019 1:17 pm@gxu
Hello my friend,
tekmed
Hello
Wifi protected setup (WPS) is a protocol that helps for connecting a home wifi network.
You press a button on your router (push button) and during 2 min you can enroll a system using WPS option of the device.
https://fr.m.wikipedia.org/wiki/Wi-Fi_Protected_Setup
Regards
Regards
tekmed
https://fr.m.wikipedia.org/wiki/Wi-Fi_Protected_Setupgxu wrote: ↑Mon Dec 09, 2019 2:13 amSorry, I don't understand what's "WPS push button mode".tekmed wrote: ↑Sun Dec 08, 2019 1:17 pm@gxu
Hello my friend,
At least enabling hability of loading a WPA key from an xml or text file will be really fine.
Or even a full xml config file ready to load with all box parameters including network
What do you think?
jifat2cool
thank you sir
Peugeot 207
Sirgxu wrote: ↑Sat Nov 09, 2019 9:23 amRelease notes:
- support t2mi
- add scam qrcode active in Network->Scam+
Warning:
- fix some bugs
1. backup of your channel/setting information, this version may lost your data.
2. Due to the scam server upgrade, you must use this new software to active the scam!
The old scam active will not work soon. It does not affect the scam that already actived.
Just now flashed my V5 with this firmware.
My question is:
You claimed : T2MI support
4.8E has one TP with T2MI frequency. ( 12188 H 30000 5/6 )
Have strong signal on 4.8E and this frequency , but nothing scanned.
Am I doing something wrong,?
Regards
- gxu
Sorry, WPS has security flaw and not in our supporting plan.tekmed wrote: ↑Mon Dec 09, 2019 7:14 amHello
Regards
- gxu
This TP is multistream + T2mi. Multistream is not supported with this chipset, you may try Hellobox 8.Peugeot 207 wrote: ↑Sun Dec 15, 2019 9:06 pmSirgxu wrote: ↑Sat Nov 09, 2019 9:23 amRelease notes:
- support t2mi
Warning:
- fix some bugs
My question is:
Regards
tekmed
Using a short and simple wpa key is also a security flaw.gxu wrote: ↑Mon Dec 16, 2019 1:44 amSorry but WPS has security flaw and not in our supporting plan.tekmed wrote: ↑Mon Dec 09, 2019 7:14 amHello
Regards
FYI WPS security flaw is only on PIN method.
do what you want sure, but it's a pitty, I've got feature on all devices I have.
At least can you PLEASE define load feature in WIFI configuration? load can be set like channel settings from a file with ease.
