DVBPlayer 1.8 release
Update:
1. Add lock/hide channel feature
2. Add alphabet,TP,FTA/CAS sorting order (in channels list and channels edit)
3. Add select default Audio Track in Settings
4. Add "SELECT ALL" option in channel delete menu
5. Fix bugs
- Screenshot_2019-03-06-13-15-30-149_com.dvbfinder.dvbplayer.png (1.11 MiB) Viewed 4906 times
- Screenshot_2019-03-06-13-14-53-660_com.dvbfinder.dvbplayer.png (338.4 KiB) Viewed 4906 times
- Screenshot_2019-03-06-13-10-24-038_com.dvbfinder.dvbplayer.png (351.79 KiB) Viewed 4906 times
- Screenshot_2019-03-06-13-09-51-427_com.dvbfinder.dvbplayer.png (341.72 KiB) Viewed 4906 times
Re: DVBPlayer 1.8 release
U click the wrong button,that function is to automatically modify the program name.aab44 wrote: ↑Thu Mar 07, 2019 10:26 amHi Fenddick,
Thanks for the new release; and here is my test result:
* Working:
-Sorting order
-Default Audio Track
-SELECT ALL option in channel delete menu
*Not working:
-Add lock/hide channel feature (When click Edit not open, just show "please wait" then disappeared)
Thanks for your great efforts.
Regards,
If u want to lock/hide channel,u should long press the channel to open the edit menu.
