Please set separated Key-input option of Biss/PowerVu
s2tv
Post by s2tv » Fri Feb 22, 2019 4:39 pm
1.if the internet is missing,all Biss/PowerVu channels will be black (it tested Softcam.Key for Biss/PowerVu channels without internet.it didnt work)
一, 如果在没有网络的情况下,Hellobox Smart S2会变成瞎子!(我也测试了Softcam.Key。按照正确的格式输入了Biss/PowerVu keys,但完全不起作用。 如果它拥有独立的Biss/PowerVu输入功能,这一切将会得到解决)
  • Softcam.Key BISS 模式 for 100.5E 12323 V 12000 新华社
    • F 00011FFF 00 2017205718201951;
      F 00011FFF 01 2017205718201951;
2.If the sever dont have some Biss/PowerVu keys,all Biss/PowerVu channels will be black( if Hellobox Smart S2 has Key-input option of Biss/PowerVu and i have these Biss/PowerVukeys ,i can input them keys for watching)
二, 如果服务器端没有一些频道的keys,Hellobox Smart S2依旧会变成瞎子!( 如果它拥有独立的Biss/PowerVu输入功能,恰好用户有这些频道的keys,用户可以输入这些keys来观看)
3.Some PowerVu channels change keys every hour(eg:AFN Network), Hellobox Smart S2 needs to more than 10 mins to find PowerVu keys, so long time,i cannt wait (if Hellobox Smart S2 has Key-input option of Biss/PowerVu, i can input keys for watching it)
三, 有些 PowerVu频道,Hellobox Smart S2需要十几到二十分钟才能找到keys,这简直是浪费时间浪费生命!( 如果它拥有独立的Biss/PowerVu输入功能,恰好用户有这些频道的keys,用户可以输入这些keys来观看)
So Please set separated Key-input option of Biss/PowerVu
如果贵公司是一个有责任感要有所作为的公司,请解决这些问题!最后祝Hellobox Smart S2大卖!
ralf0724
Re: Please set separated Key-input option of Biss/PowerVu
Post by ralf0724 » Sun Feb 24, 2019 7:37 am
我也遇到同样的问题,我收看100.5c sport feed,S2 无法及时更新bisskey,尽管我已经有key了 :(
s2tv
Post by s2tv » Sun Feb 24, 2019 9:38 am
就是这样,有key也不能看,有些时候没有biss/pv key输入选项 smart s2就是鸡肋!官方也不回应,完全没有要解决问题的态度!真是无语
Post by fenddick » Mon Feb 25, 2019 7:09 am
we r working on it,please wait...
Post by fenddick » Mon Feb 25, 2019 9:37 am
F 00011FFF 00 2017205718201951; (Forbidden 1FFF/0000,Spaces are required between keys and ;)
The correct format:
F 000100FF 00 1234567812345678 ;
s2tv
Post by s2tv » Tue Feb 26, 2019 4:57 pm
The correct format:
I tested that you told but it didnt work.there are two samples, Biss and PowerVu keys,please help me write right format to softcam. and please upload softcam,then i tested again.
#BISS KEYS
AsiaSat 5 12323 V 11999 XHLive
SID:0x0001 VideoPID:481 Biss:2017205718201951
Please help me write right format to softcam
#POWERVU KEYS
KoreanSat 5 12587 V 30000 AFN News
SID:0x0003 PMT PID:0x138B PCR PID:0x0618 Video PID :0x0618
How to know provider id?
ECM keys
00 8D817382764979
01 F99F0866EBE291
Post by fenddick » Wed Feb 27, 2019 1:52 am
The correct format:
#BISS KEYS
#POWERVU KEYS
ECM keys
00 8D817382764979
01 F99F0866EBE291
You must connect the network first...(This is bug,next version will be fixed)
PowerVu key:Provider id 0
softcam.txt
(243 Bytes) Downloaded 531 times
ralf0724
Post by ralf0724 » Wed Feb 27, 2019 3:22 am
PERFECT,
I teste write softcam as the lastest format,S2 can work on biss
s2tv
Post by s2tv » Wed Feb 27, 2019 4:54 pm
The correct format:
#BISS KEYS
#POWERVU KEYS
ECM keys
00 8D817382764979
01 F99F0866EBE291
Thanks it works for Biss and PowerVu Please upload new softcam of Irdeto/Viaccess-format when next version is upline.
Please add DiSEqC 1.2 on next vsersion
And Please add separated deinterlace that i can select on next vsersion
eg:VLC has many deinterlace modes that i can select
Post by fenddick » Thu Feb 28, 2019 1:41 am
#BISS KEYS
#POWERVU KEYS
ECM keys
00 8D817382764979
01 F99F0866EBE291
For example:
IRDETO KEYS
# provider id key index#
I 0604 02 DFDD0C4B92B4ABD26514B9AF9F0C79C4
VIACCESS KEYS
V 030B00 0D 1BCA9E886D4EBD52DA1610613C4805C1
