Hellobox V5 firmware release 20210329A
Post by fenddick » Thu Apr 22, 2021 8:35 am
This is the first firmware relase for v5, if you have a Hellobox V5, you can upgrade with this new-designed firmware.
Please keep Upgrade mode(ALL) for the first time upgrading to Hellobox V5....If you upgrade other modes, it will crash.
k5_20210329_cstm_hellobox_classical_64m_A.rar
(3.35 MiB) Downloaded 32352 times
kecenkid
Re: Hellobox 6(V5) firmware release 20210329A
Post by kecenkid » Thu Apr 22, 2021 7:21 pm
amazing its cool
can this use multistream?
Post by Garuda_ID » Thu Apr 22, 2021 9:51 pm
This is the first firmware relase for Hellobox 6(v5), if you have a Hellobox V5, you can upgrade with this new-designed firmware.
anand
Post by anand » Fri Apr 23, 2021 3:35 am
sat2ip missing please do something about
rajeevpandalam
Post by rajeevpandalam » Fri Apr 23, 2021 4:55 am
Thank You!!!
joey67
Post by joey67 » Fri Apr 23, 2021 5:22 am
Thanks for the new firmware for hellobox v5, everything working great, Scam 2.1, no freezing playing smooth,
fenddickk
Post by fenddickk » Fri Apr 23, 2021 6:02 am
Thanks, for the new update
Post by fenddick » Fri Apr 23, 2021 8:39 am
  • which version Scam is present in this version?
    can i update channel list from previous vesion DB?
    Will it wipe off my current Scam validity?
    please give answers someone
Does updating my Hellobox V5 box with this new firmware will change my box into Hellobox 6?
No, it is still Hellobox V5. Please select upgrade mode(all )when upgrading
Preiz
Re: Hellobox V5 firmware release 20210329A
Post by Preiz » Fri Apr 23, 2021 11:03 am
Hi, I tried to update the new firmware but it is telling unsupported. Pls help, I noticed that ever since I've upgraded to scam+ version 2.0 everything on my decoder change, and I can't go back to the original factory background and settings. Please help
Preiz
Post by Preiz » Fri Apr 23, 2021 12:11 pm
Still telling me unsupported. This is what I did, I downloaded the new updated firmware and rename it as autoburn_fac.bin saved it and copy to pendrive then I connect it to my hellobox v5hd.i switched it off and on then go to USB upgrade to run d firmware but still telling me unsupported.
