2.Fix some box led display problem.
Release of Hellobox GX6605S ROM New version 20210129
- Joey
1.Support wifi RT5370 and MT7601.
- GX6605s_20210129.rar
- (3.33 MiB) Downloaded 7410 times
esdhrgl1
Re: Release of Hellobox GX6605S ROM New version 20210129
But what about second language fix
UPDATE NOW SATIP BROKEN BOX HANGS TOO FREQUENTLY WHILE USING SATIP
AND ALSO CANT UPGRADE FROM ITS OWN DUMP
Super thank you
Tkumar
Great jop thanks for the latest update
- Cahel baradatu
Thank you for the update
kecenkid
Muhammad asif
-=Baber=-
surender
Thanks For Update I Found 1 Issue when I Press info button twice my Box restart every time is their any command set??
Alpha1085
But, putting both RT5370 and MT7601 on single firmware along with all new features, isn't overload on the flash? Might result in frequent hanging and box restarts.
I hope you consider adding RT5370 and MT7601 drivers on two separate firmware to reduce the load OR if possible, please make an option in merger software to integrate the wifi driver user wishes to add to the firmware.
This will simplify the things and may even save space for future upgrades. Rest depends on you. Thanks Again.
