How to imput BISS keys on the S2 box...???
I would like to know if it is possible to input BISS Keys and how can I do it...??
Thanks...!
Thanks...!
Re: How to imput BISS keys on the S2 box...???
This BOX supports two ways to import key:Paulo Hoffman wrote: ↑Mon Apr 22, 2019 2:11 pmI would like to know if it is possible to input BISS Keys and how can I do it...??
Thanks...!
1. If you have a USB connection, you can insert the USB automatic import (file name is softcam. key).
2. Put the softcam. key file into the mobile phone and remember the path,open app and enter the Device menu,select the key file under the path just now, and click Update to import.
For example:
IRDETO KEYS
# provider id key index#
I 0604 02 DFDD0C4B92B4ABD26514B9AF9F0C79C4
VIACCESS KEYS
V 030B00 0D 1BCA9E886D4EBD52DA1610613C4805C1
BISS KEYS
F 00011FFF 00 2017205718201951
Topic:
viewtopic.php?f=6&t=436
viewtopic.php?f=6&t=55
Thanks...
I'm going to try it...
I can't access the menu for searching the softcam.key file on the app...how can I do that...???
First make sure that the file is on the phone, and then go to the device of app to select the path of the file.Paulo Hoffman wrote: ↑Wed Apr 24, 2019 3:08 pmI can't access the menu for searching the softcam.key file on the app...how can I do that...???
- 1.jpg (74.17 KiB) Viewed 9272 times
- 2.jpg (72.04 KiB) Viewed 9272 times
Thank you for your kind answer...I will try it...
- GPSOFT
Please Solve Big
Biss Update Problame through softcam.key,
I tired to open mannual biss channel
Please set separated Key-input option of Biss/PowerVu
This Box is Genius but put some fuction on it,
- Just like fully web interface because user can search "satalite" channel form anywheare,
Put separated Key-input option of Biss/PowerVu,
we r working on itGPSOFT wrote: ↑Fri Jun 28, 2019 5:19 pm
Please Solve Big
Dear sir my hellobox smart s2 powervu problem not working cband 68e sony pack some channel open & not easyly biss working please dvb player input menual enter biss key option & lounch web verson, this prodecut super
