Hellobox 8 firmware release 20190814
Post by fenddick » Thu Aug 15, 2019 3:09 am
  • add DVBC support
  • add m3u player import/backup function
  • add youporn hide/show in Mainmenu->System->parent lock
  • add fav backup in upgrade
  • update dvbplayer function for scan/edit
  • powervu key enhancement
  • add "CW check" option in Mainmenu->Network->Net client config
    (Do not set "CW check" to NO if you don't know what's this)
  • add Smart RCU function, you can use any remote for the box now
    (press the Panel key LEFT for 10 seconds to start RCU learning)
Hellobox8_20190814.rar
(4.35 MiB) Downloaded 923 times
babalung
Re: Hellobox 8 firmware release 20190814
Post by babalung » Thu Aug 15, 2019 3:23 am
I hope this latest firmware can fix bugs in the old firmware on the media player; that can't display .srt subtitles when playing movie files via USB flash drive. Thanks
cybersizu
Post by cybersizu » Thu Aug 15, 2019 3:48 am
Thanks Fren......
Post by 彩票游戏 » Thu Aug 15, 2019 5:19 am
good!!
Post by fenddick » Thu Aug 15, 2019 5:29 am
ok,we‘ll fix it.
spencer26
Post by spencer26 » Thu Aug 15, 2019 5:56 am
I presume the RCU learn means press 1 three times
then press 0 then press 3
I tried this with a working remote from a dreambox and nothing.
Spencer
Post by fenddick » Thu Aug 15, 2019 7:32 am
Spencer
If you have the original controller, goto Mainmenu->Tools->Smart RCU, press the frontpanle key LEFT(<) for 10 seconds, and the remote learning will start.
Or if the original controller is lost or broken, just press the fronpanel key LEFT(<) for 10 seconds in full screen or mainmenu, it will go to the Smart RCU menu,
and the remote learning will start automatically.
Then follow the instruction on screen, press each key 3 time to match to the new remote, after finish, it will reboot automatically.
spencer26
Post by spencer26 » Thu Aug 15, 2019 10:41 am
Tried 3 different remotes. Does not work.
Spencer
Post by gxu » Thu Aug 15, 2019 11:17 am
please read the instruction, my friends
spencer26
Post by spencer26 » Thu Aug 15, 2019 12:57 pm
Followed instructions.
Left Arrow on box for 10 seconds brought up the remote on the screen.
Hit 1 1 1
No response
Hit 0 0 0
No Response from 3 different remotes.
Spencer
