Release of Hellobox GX6605S ROM New version 20210129
				Muhammad asif
Re: Release of Hellobox GX6605S ROM New version 20210129
Hello box team plz add second language.  The problem is that changing the audio of the channel and changing the channel number gives the same default sound, although this was not the case in the old version. If you want to increase the memory, delete the wifi7601 driver from the software.
				King
My box is not tuning any channel on this firmware
				singh
My box is not tuning any channel on this firmware, please help
https://mega.nz/file/et9UVCaQ#Rr2dc27gZ ... BN8fU4Njco
				Muhammedjasim
Hi.. New Rom in Add tuner AV2011 please..
				zaheer55
Re: admin fix problems  Hello box gx6605s  support Ac3 or Ac3+ Dolby digital plus support new software
									thanks scam server
				abhaysingh2009
Pls add av2011 tuner which was present earlier in first and second release.
				9shad/styles
Yes I m face same problemabhaysingh2009 wrote: ↑Sat Feb 27, 2021 1:29 pmPls add av2011 tuner which was present earlier in first and second release.
Of my ZBGX6605S AV2011 TUNER MODEL
I INSTALLED THIS VERSION BUT SIGNAL GONE
PLEASE FIX THIS PROBLEM
9$had/styles
				Muhammad asif
Lots of freezing server not stable,and hellobox team not reply why?
				Paras arya
Thank skolithawick1 wrote: ↑Sun Jan 31, 2021 1:18 pmsame thing happened to me. only solution is to completly erase the flash rom and rewrite it with new fw.Paras arya wrote: ↑Sat Jan 30, 2021 3:10 amWhen we downgrade this software with original dump .... After that I unable to upgrade with any firmware/hellobox firmware...By usb.
.please give the solution...
				sachinverma
Can we use this software for another Hellobox settop box, means Hellobox v5HD etc
