how to upgrade Hellobox V5 plus through RS232 serial port?
				koaung.keypro
Re: how to upgrade Hellobox V5 plus through RS232 serial port?
Hello.please we are hello box v5 hd machine Sun Tv next tv lile not Open so we how to do it? Please help me. Thank you
				Jass thind
How to upgrade hello box v6 by rs232 cable
				Jass thind
				Vinodjangird
Pls renew the link
Link is not working
						Link is not working
				WilliamNeivy
- Contact:
Im trying to control PMAC through serial port from a terminal. I tried different terminals, successful with some, e.g., Tera Term, and unsuccessful with others. It seems its due to the terminator sent at the end of the command. Whats the correct format for the command sent and status read back?
				IDSOLA
"can't sync with btinit_ddr2_400m_debug.img"
I am getting the above in the process of waking up a dead V5plus that has been upgraded to Hellobox6.
Kindly help with solution
Use flashing CH341A
Make sure the com port is set to 115200 , Rename the dumped bin file to hellobox_v5_plus.bin
Use Cross null RS232 cable
				sunny09
It's an invalid link 'code'.DVBFinder wrote: ↑Sun Dec 23, 2018 2:18 am1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
2. Insert the USB device to Hellobox V5 Plus Support and receiver
3. Connect Hellobox V5 plus with computer through RS232 cable
4. Run "WinSTBUpgrader.exe "on computer
5. Select and Open serial port
6. Click" download "page, select the config file " V5 _plus_8M.xml "
7. Click" Start "
8. Power on Hellobox V5 plus, and wait ...
After upgrading is done, Hellobox V5 plus will reboot automatically.
Please enjoy and download the tool RS232 here :
https://my.pcloud.com/publink/show?code ... CQs8yxQ6SX
Please provide the proper link thanks
				sunny09
Help me pleasesunny09 wrote: ↑Wed Feb 10, 2021 11:46 amIt's an invalid link 'code'.DVBFinder wrote: ↑Sun Dec 23, 2018 2:18 am1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
7. Click" Start "
				sunny09
Anybody can send the file
