Release of Hellobox CS8001 ROM New version 20210121
Re: Release of Hellobox CS8001 ROM New version
Tried auto_burn.fac, flash.bin, recover.bin etc... But failed to update...
- maxx
My bad, I was wrong about the SCom. It's okay now. Thank you, great work Hellobox!fenddick wrote: βMon Jan 25, 2021 9:06 amChange bin file to auto_burn.fac Automatic upgrademaxx wrote: βSun Jan 24, 2021 7:00 amvlcsnap-2021-01-24-13h53m01s334.png
Above is my Skybox A-1 New. I tried flashing the new Hellobox CS8001 on to it, but it failed with these errors:
I also tried to install this firmware via SCom v4.2.0.0, but it also failed with error on panel showing a "FFFF". Am I misinterpreting the CS8001 for the box I have?
I have done this software, now my receiver signal is not picking up, do my help plz.
- Hellobox_CS8001_20210121_A.rar
- Hellbox cs8001 20210121
- (3.37 MiB) Downloaded 3513 times
REMOTE KEY
PANEL LED KEY
TUNER
- Cahel baradatu
please update the UI for this software
I am using cs8051t as my skybox a1 plus h.265 onboard chipset, it's work. Not sure 'bout scam cause i'm prefer to c bandrajeevpandalam wrote: βThu Jan 21, 2021 11:18 amTjis is my solid 8181 box installed with solid 2100dlx software
Is it working on your 8051t chipset?alpin sahilatua wrote: βThu Jan 28, 2021 4:57 pmI am using cs8051t as my skybox a1 plus h.265 onboard chipset, it's work. Not sure 'bout scam cause i'm prefer to c bandrajeevpandalam wrote: βThu Jan 21, 2021 11:18 amTjis is my solid 8181 box installed with solid 2100dlx software
- urfan.web.id
Skybox_A1_New_CS8001_20210121_A
CS8001 ROM New Version for Skybox A1 New
- Skybox_A1_New_CS8001_20210121_A.rar
- (3.37 MiB) Downloaded 3239 times
- urfan.web.id
You can upgrade with this file using usb recovery mode for Skybox A1 New, change bin file name to flash.bin and press the menu button repeatedly on remotemaxx wrote: βSun Jan 24, 2021 7:00 amvlcsnap-2021-01-24-13h53m01s334.png
- (3.37 MiB) Downloaded 3901 times
