Post
by fenddick » Tue Apr 23, 2019 2:57 am
Paulo Hoffman wrote: ↑Mon Apr 22, 2019 2:14 pm
On the specifications of the S2 Box you say that it have a embed Wi-Fi ...but it doesn't...
It only work if it is connected to a router...with wi-fi...so...why you announce it on the specs if it don't have any wi-fi module...??
This box has WiFi devices.
How do you connect to a router without a WiFi module???
Anubis86
Post
by Anubis86 » Mon Nov 25, 2019 1:46 pm
After latest update box always disconnects from any of my previous phones.
And if I attach Lnb cable it never pair or connects in either dvbplayer or dvbfinder app.
Before updates in 2018 there was no such problems at all.
Please developers resolve this problems, I loved this tiny box.
Post
by fenddick » Wed Dec 04, 2019 1:48 am
Anubis86 wrote: ↑Mon Nov 25, 2019 1:46 pm
This is a bit complicated. First you need a flash burner, and then you need to remove the flash from the stb,Finally burn firmware in it.
Anubis86
Post
by Anubis86 » Sat Jan 15, 2022 10:16 am
Developers pls revert to a stable firmware of Smart S2.
Problems I'm facing:-
Never connects with bluetooth.
Never saves wifi password & prompts to feed password again & again.
Even though if its somehow gets connected via bluetooth, when I insert LNB cable it instantly disconnects.
I have used in the box charger & cable.
All these problems I facing since end of 2018 but no hope.
PLS PLS PLS HELP.
