Please I want a picture of the board
Please I want a picture of the board or the image of the electronic circuit
Re: Please I want a picture of the board
here some photos i taken
https://imgur.com/a/f5MmDR5
not all good but is to give a shoot, found something interesting?
legolas wrote: ↑Thu Aug 06, 2020 11:15 pmhere some photos i taken
Thank you, I want the IC number
Hi, What is the tuner chip here? there is a 5815M (RDA5815M) tuner chip in the Hellobox B1.
- 7CrMGb1.jpg (178.78 KiB) Viewed 5889 times
Wifi Mod?
is it possible to make a mod in wifi to make it dual band or atleast upto 300mbps either by replace a RTL8188EUS module or by connecting another USB wifi dongle b/c this module is also a USB based.
and if i connect another wifi USB to its stereo USB pin(LAN Connector). will that work? does firmware support other wifi devices?
Regards
Regards
Hi Everyone,
To avoid confusion, I would like to delete the event posts after the date has passed. So that you dont loose content, please dont post photos or other information you dont want to see removed. You can use the event photos board for that.
Kurt
Kurt
