Hellobox 6 firmware release 20201207
Jithin009
Re: Hellobox 6 firmware release 20201207
Post by Jithin009 » Wed Dec 09, 2020 4:22 pm
tanimreza wrote:
Wed Dec 09, 2020 2:19 pm
Wed Dec 09, 2020 9:44 am
tanimreza wrote:
Wed Dec 09, 2020 6:42 am
how to use auto_burn.fac???
1.Unzip the rar file and rename the file "auto_burn.fac ”
2.Put in the U disk, automatically upgrade
3.The panel will show FFFF
4.Restart
Then any problem for existing scam???? :?: :?: :!: :oops:
No
saadia
Post by saadia » Wed Dec 09, 2020 7:08 pm
Dear Sir,
after upgrading the above software in v5 plus,
what ar the benefits
is airtel not freezing etc
thanks
jab
fdl
Post by fdl » Wed Dec 09, 2020 7:40 pm
hey
friend I am unable to connect my CCCAM lines most of times, I am using 16 lines simultaneously but hardly can connect 1 or 2 line, Kindly guide me what is the Issue, I have hellobox v5 plus and I am from india, I flashed it hoping that hellobox 6 firmware will solve my issue but no use. Now my SCAM+ is also not working because earlier channels would turn blue but now they are not.
Post by car mel » Thu Dec 10, 2020 2:35 am
Some inputs noticed after testing:
-Do not see the Power Vu keys # import message when internet connected like all previous version
-Menu Sections are missing the pull down menus, hard to know what it is inside each section unless you go in
-Hard Reset On/Off sometimes is required after each satellite scanning to activate the auto biss option on Biss channels
Keep up the good work!!
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
Shahin sarkar
Post by Shahin sarkar » Thu Dec 10, 2020 6:41 am
Hello Dear..
Good morning. Last night i was updated my Hellobox v5 plus with new software.
In this update may be New looks only available. Later i try to open 119 BS-1 satellite tv channel Duronto tv in biss key mood.
I keep on this channel but biss key not auto rolled.
Server channels colors are shows blue.
it is also looking not very good.
Reading channels name are very hard to see in blue color.
If it is Green or yellow may looks better & easy.
"3G connected" pop up massage appears frequently like before. 4G network not found in Network options.
If power off by the remote box goes on stand by mood. When again on Network card not available shows same as before.
I think i have to roll back on previous version until fixing those issue.
Shahin Sarkar.
Dhaka
Bangladesh.
saminasir
Post by saminasir » Thu Dec 10, 2020 7:31 am
Naveen.land4
Post by Naveen.land4 » Fri Dec 11, 2020 6:06 am
Thanks for the update. But unable to restore the channels which were taken from v5+ Previous updated...
wahyu d.w
Post by wahyu d.w » Fri Dec 11, 2020 4:09 pm
hi hellobox why there is no additional scam for one year. whereas for other receivers (outside Hellobox) which is gx6605S, you give that
wahyu d.w
Post by wahyu d.w » Fri Dec 11, 2020 4:10 pm
iri bilang boss 🤣🤣🙏🏻
amr
Post by amr » Wed Dec 16, 2020 6:53 pm
okkkkkkkkkkkkkkkkkkkk
