Please somebody can help me.
my hellobox v 5 plus doesn't detect wife internet.
I need help.
help
Re: help
Try plugging WiFi in and out,nsabimana moussa wrote: ↑Fri Jul 10, 2020 7:35 amPlease somebody can help me.
I need help.
dhk
Re: help
It seems that if you had connected using a WiFi connection ( hotspot or router) and then switched of the ird without logging off and then turn off that wifi access, the ird dies not show any networks even if you search. The only solution for now is to switch on the other wifi hotspot device ( or rename a hotspot to the one you last connected to the ird) and disconnect from that and reconnect to another network of your choice, provided it will be there the next time you restart the ird.nsabimana moussa wrote: ↑Fri Jul 10, 2020 7:35 amPlease somebody can help me.
I need help.
Re: help
That's how we designed it,After you turn off the hotspot, wait 2-3 minutes to re search WiFi and connectdhk wrote: ↑Wed Jul 15, 2020 3:42 amIt seems that if you had connected using a WiFi connection ( hotspot or router) and then switched of the ird without logging off and then turn off that wifi access, the ird dies not show any networks even if you search. The only solution for now is to switch on the other wifi hotspot device ( or rename a hotspot to the one you last connected to the ird) and disconnect from that and reconnect to another network of your choice, provided it will be there the next time you restart the ird.nsabimana moussa wrote: ↑Fri Jul 10, 2020 7:35 amPlease somebody can help me.
I need help.
