how to upgrade Hellobox V5 plus through RS232 serial port?
Re: how to upgrade Hellobox V5 plus through RS232 serial port?
Compare file on USB to be sure it reads exactly like this...hellobox_V5_plus.bin
maxy
Yes its FAT32 Formatted 1GB USB Pen Drive.
only hellobox_V5_plus.bin is there under root.
hermanku
I can not download this file..DVBFinder wrote: ↑Sun Dec 23, 2018 2:18 am1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
2. Insert the USB device to Hellobox V5 Plus Support and receiver
3. Connect Hellobox V5 plus with computer through RS232 cable
4. Run "WinSTBUpgrader.exe "on computer
5. Select and Open serial port
6. Click" download "page, select the config file " V5 _plus_8M.xml "
7. Click" Start "
8. Power on Hellobox V5 plus, and wait ...
After upgrading is done, Hellobox V5 plus will reboot automatically.
Please enjoy and download the tool RS232 here :
https://my.pcloud.com/publink/show?code ... CQs8yxQ6SX
bloomer
hermanku wrote: ↑Wed Sep 04, 2019 3:27 pmI can not download this file..DVBFinder wrote: ↑Sun Dec 23, 2018 2:18 am1. Copy bin file to a USB device and change to the file name to "hellobox _ V5 _plus.bin"
7. Click" Start "
[Me either. Link is dead.]
helloboxv5plus
7. Click" Start "
elanimal19
ineed help
Serial Port Opened
monitor start
download start
Please reboot the STB manually.
Change baudrate to 115200.
monitor stop
Sync Succeed.
Sending boot init...
Send boot init completed.
boot init run successfully.
SendClient.
Sending Client is complete.
Client is up.
Client Functionality is good.
uboot run successful
download successful!
monitor start
usb start;fatload usb 0 83000000 hellobox.bin;sf burn 83000000 0 400000;
(Re)start USB...
auto_detect_usb_port --- usb default sel port 1
port_sts0:0x00000803 port_sts1:0x00000803
auto_detect_usb_port --- usb sel port 1
USB: usb_debug
need usb1 plug in....
usb1 device connect port status :0x1803
port1 reset down port status :0x8001205
ehci_hcd_init...
Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
scanning bus for ethernet devices... 0 Ethernet Device(s) found
** Unable to use usb 0:1 for fatload **
do_spi_flash_uboot_save offset[0] len[2d600000]
spi0 is already setup!!!
SF: spi flash status register: 0x00, 0x00
SPI: Detected EN25Q32B with erase size 64 KiB, total 4 MiB
Serial Port Opened
monitor start
download start
monitor stop
Sync Succeed.
SendClient.
Client is up.
monitor start
(Re)start USB...
USB: usb_debug
ehci_hcd_init...
USB EHCI 1.00
[email protected]
My hellobox v5 plus does not start, it stays in boot and usb, I already tried the procedure of the rs232 cable and it shows me an error, what can I do?
Please try to rename the new software to auto_burn.fac ,Then save it to USB flash disk, insert STB before power on, the panel will display usb and percentage, restart after completion (unplug USB disk and delete the file).[email protected] wrote: ↑Tue Jul 21, 2020 3:39 amMy hellobox v5 plus does not start, it stays in boot and usb, I already tried the procedure of the rs232 cable and it shows me an error, what can I do?
ViaHussun
7. Click" Start "
Link dead
