Please solve the following issues/problems
Alpha1085
Post by Alpha1085 » Sun Mar 20, 2022 6:29 am
Hello
Aside from few issues, this is a wonderful software for GX6605s series boards. Kindly solve the following issues that are still happening even in the latest march update 20220304.
1: Language issue, in multiple language channels, when we select the audio stream, it does not stick and we have to change it again and again to make it work. To solve this, kindly add other system languages (aside from English) so that we can select different language for first audio and second audio options in language menu.
2: cccam or cline does not work properly, channels freeze up.
3: pvr recording option does not work at all. Why this option is even here wasting precious flash space? Every time I try to record something using timer option, it says "pvr is not supported". Please remove this option all together if you can't fix it.
Kindly fix the above issues so that it's worth taking your scam+ subscription.
Regards!
