Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Re: Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
please help me, can't copy the led panel
here the original bin
https://www.freedvb.com/download/file.php?id=992
- Not support
- Capture.PNG (35.87 KiB) Viewed 42973 times
- Joey
- Joey
hanwool wrote: ↑Fri Feb 05, 2021 2:30 amplease help me, can't copy the led panel
Your original bin did not contain panel config,so not support merge panel
But others merge ok.
http://www.freedvb.com/viewforum.php?f=28
thanks so much friend
Can you add language switching feature? when I open and change the software, it turns itself off after a while
My box is not tuning any channel on this firmware, please help
https://mega.nz/file/et9UVCaQ#Rr2dc27gZ ... BN8fU4Njco
Thanks for the work but scam mostly does not work at all either status is idle, initialing or working.Please provide strong system so that we can watch paid channels very easily.
CaN somebody share his dump of this firmware installed ? Cant get pass through boot screen with DVB finder Scan to Activate - every time I put the code and press Ok - nothing happens at all . The reciever keeps rebooting after while not accepting the code
Hellomerger crashes in Win 10 64bit, when we select the original dump file of Solid 6363
Can you help with this original bin to find the issue (Rename the extention .jpeg to .bin)
