HELLOBOX GX6605 ROM
HELLOBOX GX6605 ROM
Scam+ sarver down today not working airtel 108.2E
Re: HELLOBOX GX6605 ROM
Hello friend do you solved this issue?
I have the same problem, Tandberg not open the chanel
- Joey
Please record the stream for us,the duration more than 10 minutes.
Connect the portable hard drive
input 7791 on the powervu program
TP record will start
(DO NOT USE USB flash disk ,performance BAD.)
and send to me the Tandberg keys
then we will test it.
I m face same problem on 42e Turksat Fox network
Tandberg key Not working
Please Solution
Please Solution
9$had/styles
