Release of Hellobox GX6605S ROM
kecenkid
Re: Release of Hellobox GX6605S ROM
Post by kecenkid » Thu Nov 19, 2020 12:22 am
hi im so exited with new update from hellobox gx6605s fix some channel now is good,
i hope you always trying for best to this firmware like fix usb tethering, fix signal reading...
that will be cool
thank you for your update
Post by fenddick » Thu Nov 19, 2020 5:46 am
that will be cool
We will do our best.
dhk
Post by dhk » Thu Nov 19, 2020 8:43 am
[/quote]
[/quote]
Could you please provide a similar hellobox sw for sunplus 1506c v 2.1 hevc box?
samar_sandhu
Post by samar_sandhu » Thu Nov 19, 2020 3:47 pm
it never autoconnects 3g wheather u shutdown by power or restart from remote
rico
Post by rico » Thu Nov 19, 2020 3:57 pm
@fenddick,
Can you please add about 20 YouTube Channels in Hellobox firmware ?
Regards
kuzown
Post by kuzown » Fri Nov 20, 2020 6:45 pm
Hi everybody,
I own a gx6605s STB, which very often hangs, while changing the channels. The solution to fix it to disconnecting it from the power cord. Looks like the stock firmware is not so stable, so I decided to flash ot with the new Hellobox ROM. I transferred, as explained, the remote keymap and front panel data, using the original bin. After I copied the new generated bin to an empty fat32 pendrive. But when I tried to flash it, I got a message “Error occur” and nothing else happened.
Does anybody have an idea what is wrong? Is my receiver somehow not compatible? As I understood, the Hellobox rom is suitable for all gx6605s boxes, or I am wrong? Can somebody help me?
Thanks in advance!
Post by Yawwilson » Fri Nov 20, 2020 6:51 pm
Well, if your box is compatible ,then I believe you have to rename the rom to "auto_burn.fac"..it was stated in the flashing process...to be double sure, go back and read the flashing process again...
kuzown
Post by kuzown » Fri Nov 20, 2020 7:09 pm
Tried this as well, but nothing happens. After i plug the pendrive and restart the receiver, it just boots up as usual...
Post by car mel » Sat Nov 21, 2020 12:45 am
Have you created the Hellobox file for your box using your box FW and the Hellomerger V1.1??
http://www.freedvb.com/viewtopic.php?f=27&t=19119
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
kuzown
Post by kuzown » Sat Nov 21, 2020 5:33 am
Yes, I did it.
It is successfully generating new bin, which I cannot flash on my STB.
