DUMP HELLOBOX 8
david0302
DUMP HELLOBOX 8
Post by david0302 » Fri Apr 01, 2022 9:12 pm
Dear www.freedvb.com. please give a full dump of 8 megabytes to revive our dvb box. We flashed it from your firmware, because of this, now the box does not work, it has dead. Only the red light on the front panel is on. recovery did not help, even rs-232 cannot send the firmware file to the tuner. boot partition is corrupted. The only hope is to flash the memory itself. your firmware is 6.55 megabytes, and we need a full dump of 8 megabytes. help us someone please give a full dump to revive our hellobox 8 dvb
danhthao
Re: DUMP HELLOBOX 8
Post by danhthao » Sat Apr 02, 2022 2:46 am
replace ic flash
david0302
Re: DUMP HELLOBOX 8
Post by david0302 » Sun Apr 10, 2022 1:55 pm
this tuner has native flash memory EON Q64-104HIP. Replaced with W25Q64VB (WINBOND) 8 megabytes. now you need to flash the full bootloader and the firmware itself. but the dump file is nowhere to be found. Does anyone have a dump of this tuner? can you upload the dump file?
edzus1
Re: DUMP HELLOBOX 8
Post by edzus1 » Mon Apr 11, 2022 1:54 am
viewtopic.php?f=25&t=18630
