Hellobox 8 firmware release 20200904
Post by fenddick » Fri Sep 04, 2020 10:02 am
  • add Stream out(Tools) function
  • Fixed bug
Stream out:Enter the IP address of the PC, the port can be customized, select on, and then go to the PC side to open the VLC, enter the media open network stream, and enter the udp://@:port to play the programs on the STB
Hellobox8_20200904.rar
(4.29 MiB) Downloaded 975 times
yoroshii
Re: Hellobox 8 firmware release 20200904
Post by yoroshii » Fri Sep 04, 2020 11:32 am
Sumitro Ananda
Post by Sumitro Ananda » Fri Sep 04, 2020 12:41 pm
stefanose
Post by stefanose » Fri Sep 04, 2020 2:51 pm
thanks
Ko ko aung
Post by Ko ko aung » Fri Sep 04, 2020 2:58 pm
I have entered IP address of PC on hellobox V8.Tired inputting udp@ on VPL media but it is not working.
So I need to be clear.Do u have spaces while putting port on vlc media?
Do u choose "play" or "stream" after inputting port?
Also how long do I need to wait for the loading to finish normally?
Ty in Advance
Post by 彩票游戏 » Fri Sep 04, 2020 10:10 pm
20200905_h8中文固件.zip
(4.9 MiB) Downloaded 364 times
Post by Yawwilson » Fri Sep 04, 2020 11:10 pm
Appreciate your hard work..
cborromeo
Post by cborromeo » Sat Sep 05, 2020 3:30 pm
Thank you so much.
Post by fenddick » Mon Sep 07, 2020 2:00 am
Ty in Advance
1.Input the IP&port of PC to hellobox
2.Stream out turn “on”
3.Open VLC->Media->Open Network Stream->Network->Enter udp://@:port ->Play
4.STB exits to full screen, and the program to be played needs to be consistent with VLC
Post by gxu » Mon Sep 07, 2020 2:03 am
Ty in Advance
if you switch channel on Hellobox 8, you should reselect the program on vlc/potplayer, or stop and restart
