Hellobox 8 recording problem
Drako
Hi, I just bought the Hellobox 8 with the latest s/w version, all is good but I hace a problem the recordings stop before they should, programmed of direct they stop for no reason, I use to record some shows for 5-6 hours and when I came back it only recorded 3 hours, or if I let it recording for 3 hours it records 2.
All my HDD are fine, I have actually a Hellobox V5 with old version and that works good with recordings, I don´t want to return this one, please help me!!!
ROB
ROB
Re: Hellobox 8 recording problem
Hi, it is a problem that I had already reported Sat Aug 31, 2019
viewtopic.php?f=25&t=18400
Timer scheduled recordings sometimes work, sometimes not!
http://www.freedvb.com/viewtopic.php?f= ... 592#p22592
Very long recordings (many hours) end before scheduled time!
and Sat Sep 28, 2019 11:42Cluster.One wrote: ↑Sat Aug 31, 2019 4:53 pmWith the decoder in standby mode , timer scheduled recordings sometimes work, sometimes not... more no than yes (even if I inserts all the right settings and the and the clock is is Ok...)
With the decoder On, timer scheduled recordings seem to work well
If I program Timer and then leave the decoder in standby mode Hellobox 8 turns on at the scheduled time then a sign appears with the words: go to standby in 15 sec. and does not record anything... (even if I inserts all the right settings and the clock is is Ok...)
Leaving the decoder turned on is a useless power consumption...
All decoders I own start scheduled recordings from standby...
Is it possible to make scheduled recordings work even if Hellobox 8 is left on standby?
does it also happen to someone else?
I'm sorry to say because despite everything I like Hellobox 8, but it seems like they didn't do anything to fix it...Cluster.One wrote: ↑Sat Sep 28, 2019 9:42 amThis happens both with manual and timer recording...
And it's not a problem of USB or HDD capacity...
If all bugs of Hellobox 8 were fixed could become a good box...
Though I start thinking that all these problems of Hellobox 8 will never be solved![]()
We'r working on it.Drako wrote: ↑Sat Aug 08, 2020 12:16 amHi, I just bought the Hellobox 8 with the latest s/w version, all is good but I hace a problem the recordings stop before they should, programmed of direct they stop for no reason, I use to record some shows for 5-6 hours and when I came back it only recorded 3 hours, or if I let it recording for 3 hours it records 2.
ROB
Drako
Great! How is it going on with this fix? it is a great box, just need some fix for the PVR and recordings
Drako
That is the problem, so the recordings are not safe
Cluster.One wrote: ↑Sat Aug 08, 2020 10:47 amHi, it is a problem that I had already reported Sat Aug 31, 2019
Timer scheduled recordings sometimes work, sometimes not!and Sat Sep 28, 2019 11:42Cluster.One wrote: ↑Sat Aug 31, 2019 4:53 pmWith the decoder in standby mode , timer scheduled recordings sometimes work, sometimes not... more no than yes (even if I inserts all the right settings and the and the clock is is Ok...)
Very long recordings (many hours) end before scheduled time!I'm sorry to say because despite everything I like Hellobox 8, but it seems like they didn't do anything to fix it...Cluster.One wrote: ↑Sat Sep 28, 2019 9:42 amThis happens both with manual and timer recording...
Drako
So the Hellobox 8 20200904 software did not fix the pvr recording problem...
Drako
Hi, Is there a solution for the Hellobox 8 Recording problem???
Drako
Is there a solution for the PVR recording problem???
we are sorry about this problem, it need totally rewrite about the file system.
Recording for more than 4G would not be available is short time.
