May I ask the engineer which of the following files is the PLs code folder?
May I ask the engineer which of the following files is the PLS code folder? What tool can I use to open it without scrambling?
As the STB is a built-in multi-stream PLS code, the STB firmware file is missing two sets of PLS scodes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
- Screenshot_20200807_102759.jpg (1.09 MiB) Viewed 3016 times
Re: May I ask the engineer which of the following files is the PLs code folder?
As the STB is a built-in multi-stream PLs code, the STB firmware file is missing two sets of PLs codes, 11633 and 11669 of Taiwan ST-2 satellite. PLs code needs to be added, but I do not know which file is used to store PLs code. Does anyone other than the engineer know?
Pls:
11633 H 30000,pls 260334;
11669 H 30000,pls 248232;
We know that IR1 and IR2 are remote control codes. What are the others? What tool can I use to open it without confusing code?
我看你多次反映这个88ku plsn问题官方都不愿意植入,应该是国内用户太少的原因。他觉得没必要去开发。
If you don't want to develop it, tell us how to do it. Do it ourselves
