Hellobox 8 firmware release 20200410
Post by fenddick » Mon Apr 13, 2020 2:43 am
  • Add hellobox8 logo in the information menu
  • Fix some bugs
Hellobox8_20200410.rar
(4.5 MiB) Downloaded 619 times
cyberworld23
Re: Hellobox 8 firmware release 20200410
Post by cyberworld23 » Mon Apr 13, 2020 3:14 pm
  • Fix some bugs
I'm using hellobox 8 new, after upgrade youtube still not run like firmware before. I'v tried with vpn, but still with the same result. How about other? plz let me know
Kyaw shwe
Post by Kyaw shwe » Mon Apr 13, 2020 4:03 pm
  • Fix some bugs
machteck
Post by machteck » Tue Apr 14, 2020 12:04 am
  • Fix some bugs
Hello fenddick is this new release for the new box 8 or the original box 8 or will it work on both ? Thanks
Post by fenddick » Tue Apr 14, 2020 2:14 am
  • Fix some bugs
It will work on both.
machteck
Post by machteck » Tue Apr 14, 2020 12:29 pm
  • Fix some bugs
Thank you.
Post by 彩票游戏 » Tue Apr 14, 2020 10:31 pm
kalmars
Post by kalmars » Sat Apr 18, 2020 8:36 am
The last two versions of Hellobox 8, 20200410 and 20200320, cannot be used with protocol 1.2
  the engine is cut with a delay or does not turn at all, must be skipped several times
on the channel to start moving, does not switch when entering the satellite, behaves incorrectly when adjusting,
  then rotates continuously, then step by step, then does not rotate at all, if you switch tp and then start rotating,
There are so many mistakes that cannot be described. In version 20191226 at least everything worked.
