Ac3 and Digital Dolby +
pierangelo74
Re: Ac3 and Digital Dolby +
Post by pierangelo74 » Sun Jul 28, 2019 6:26 am
Post by fenddick » Mon Jul 29, 2019 2:37 am
pierangelo74 wrote:
Fri Jul 26, 2019 9:31 am
"Now" means?
1) Only untill we improve/ change software;
2) Forever.
This batch of hardware is not supported , it will take a long time. sorry
Since1890
Post by Since1890 » Mon Jul 29, 2019 1:46 pm
MIERDA DE PRODUCTO Y RECEPTOR , MUY CARO Y NO ES COMPATIBLE EL SONIDO ....UNA ESTAFA
Since1890
Post by Since1890 » Mon Jul 29, 2019 1:52 pm
"Now" means?
2) Forever.
ESTO SIGNIFICA ENGAÑAR A LOS USUARIOS CON UN PRODUCTO MALO Y OBSOLETO NO REPRODUCE SONIDO AC3 Y DIGITAL DOLBY + Este lote de hardware no es compatible, llevará mucho tiempo.
pinolo
Post by pinolo » Mon Jul 29, 2019 2:00 pm
@Since1890
Set Audio Out on AV Setting (LPCM Out/BS Out)
pierangelo74
Post by pierangelo74 » Mon Jul 29, 2019 2:50 pm
Dears,
my experience with LPCM out and an old tv is negative, but with a newer tv (3 years old and 4k )able through HDMI to understand AC3+, the sound is ok.
No problem on AC3.
regards
Since1890
Post by Since1890 » Mon Jul 29, 2019 6:04 pm
Dears,
my experience with LPCM out and an old tv is negative, but with a newer tv able through HDMI to understand AC3+, the sound is ok.
No problem on AC3.
regards
mira decir que no hay problema con el sonido AC3+ ES SENCILLAMENTE MENTIR .. TENGO UN TELEVISOR NUEVO , SE DE ESTO MUCHO Y O BIEN SACAN UN FIRMWARE QUE SOLUCIONE EL PROBLEMA O ESTO NO FUNCIONA, QUIZAS SEAS UN INFILTRADO PARA CONFUNDIR A LOS USUSARIOS PERO A MI NO ME ENGAÑAS ...
Since1890
Post by Since1890 » Mon Jul 29, 2019 6:05 pm
Dears,
No problem on AC3.
regards
pierangelo74
Post by pierangelo74 » Mon Jul 29, 2019 8:26 pm
BS out,
And try.
Ciao
Pierangelo
Italy, no china!
pierangelo74
Post by pierangelo74 » Tue Jul 30, 2019 9:45 am
@ Engineers
Please, Something must be done!
https://en.wikipedia.org/wiki/AC3Filter
even turning ac3+ in a mono sound, can be acceptable.
please, do something.
I would want to use the HB8 on a 10 years flat tv, and I got only ac3
:roll:
