Hellobox 8 upgrade introduction
Re: Hellobox 8 upgrade introduction
Post by car mel » Sat Jul 06, 2019 10:09 pm
Since there is NO RS232 connector I will like to see some more info to recover the unit if stuck or brick. This is from your spec's:
"RS232 upgrade"
"This is the last way to recover the box. it requires you to open the box cover and connect the RS232 cable to PC.
Remove the screws under the box
Open the box very carefully! The WIFI antenna is connected to the box cover
Insert a 3-wire RS232 interface, and connect the RS232 to PC
Upgrade using PC tool."
What 3 wire RS232 cable interface are we talking about?
Can you post a picture of where should be connected?
Where is the PC Tool to do so??
What image file or firmware will be required to do so??
Finally, a Channel Editor should be a priority as well.
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
ZinKo
Post by ZinKo » Sun Jul 07, 2019 6:47 am
Where is hellobox8 firmware? I cannot find this firmarwe released or not?
Post by gxu » Mon Jul 08, 2019 2:03 am
"RS232 upgrade"
Be patient, we will update this part with picture later.
Post by gxu » Mon Jul 08, 2019 2:05 am
We are now improving the software continuously, and the newer version will be released in "Hellobox 8" section, just as did for V5Plus.
烧星1号
Post by 烧星1号 » Mon Jul 08, 2019 9:07 am
希望你们hellobox 8团队能开发中文固件,thank you!
zhaoqingzhu
Post by zhaoqingzhu » Tue Jul 30, 2019 9:06 am
hello!when the rs232 upgrade tool be released? thanks!
maicol72
Post by maicol72 » Tue Jul 30, 2019 3:29 pm
Please fix the problem that after the upgrade it doesn't keep language and usals settings
Post by fenddick » Wed Jul 31, 2019 2:31 am
Not support keep language and usals settings.
maicol72
Post by maicol72 » Wed Jul 31, 2019 1:01 pm
OK thanks
Post by gxu » Thu Aug 01, 2019 3:20 am
Update the RS232 upgrade section, also the pc tool.
