My device died after the update? new version (usb)
formula
Post by formula » Mon Apr 12, 2021 2:23 pm
My device died after the update, what should I do? The red bulb only works?
new version not old version (usb) !
Jagosto
Re: My device died after the update? new version (usb)
Post by Jagosto » Thu Apr 15, 2021 11:22 am
I do have the same problem this recovery firmware ( auto_burn.fac) as been sento to me to try recovery but I have no luck 😭😭
formula
Post by formula » Mon May 10, 2021 7:32 am
Hi
1- please i want hellobox8.xml for winstbupgrader because it dmg.
error msg:
Aparse config file error!
2- please load hellobox8_upg in in another host:
https://drive.google.com/open?id=1ldPlZ ... aRLpji_V-M
i can't download it.
regards
formula
Post by formula » Mon May 10, 2021 2:05 pm
sathex
Post by sathex » Fri May 14, 2021 11:00 am
is this work like rs232 (usb ttl)
do not wait and test, there is nothing to fear...
just refer to readme_download.jpg for hellobox8_upg usuage
formula
Post by formula » Fri May 14, 2021 2:14 pm
thank you, but when i download it, my tablet save it:
Helobox8...... rar.mhtml
the size: 1.2 Mb
not the right rar file!
please upload it in mediafire.com
sathex
Post by sathex » Sat May 15, 2021 8:34 am
the size: 1.2 Mb
https://www.mediafire.com/file/gx292hii ... 0.rar/file
formula
Post by formula » Sun May 16, 2021 4:48 am
the size: 1.2 Mb
thank you mr. sathex
after download, i used the program (Hellobox8_upg. exe), i got error msg:
serial port opened
reboot the stb manuallysync success
download start
change baudrate to 115200
sending boot init
send boot init completed
boot init run failed
m_download_thrd is stop!
m_sp__mnt_thrd is stop.
sathex
Post by sathex » Mon May 17, 2021 12:44 pm
1st solution:
uses a former flash or dump of preference
Renow your flash in :
auto_burn.fac
of course with extention "fac" and not "bin"
Format your flash disk (FAT32)
Used it with the program (hellolox8_upg Exe) as described in the photos.
if don't work...
rename the upgrade sw file to flash.bin,and then storage it in the USB
2EM solution:
uses the same program but on upgrade
Do not forget about Click on "Erase All"
finally if the problem persists you have to see if there is a hard problem
See also if there is an error in the procedure and configuration. ect.
Review what is described on this page in particular
the "auto upgrade" part
https://www.freedvb.com/viewtopic.php?f=25&t=14226
Note:
Personally I'm having fun with my receivers
By making transformations of all kinds...
And I have never had difficulties in their initial state!
so for you too
it sufits to find the right configuration.
Finally I think your problem comes from the procedure
because it is important to put the program in the root C: \
the program should work
:mrgreen:
