Problems with Discovery MUX PowerVU keys sat 58w
New satellites/transponders/channels, satellites/transponders/channels removed, etc.
NOWAR
Post by NOWAR » Fri Nov 12, 2021 10:33 pm
Problems with Discovery MUX PowerVU keys on the 58W IntelSat 21 satellite, only opens the audio and puts the fully black screen
Peugeot 207
Re: Problems with Discovery MUX PowerVU keys sat 58w
Post by Peugeot 207 » Sat Nov 13, 2021 7:24 am
The good thing against other boxes is that channels remains visible even after broadcaster changing. But, if you do a rescan, than channels stored as radio station with VPID: 0000.
So:
DO NOT A RESCAN and everything will be OK.
"Losted" channels stored as radio station can't be VPID edited to be restored as video channels.
Does somebody know how to edit VPID's?
NOWAR
Post by NOWAR » Sat Nov 13, 2021 10:51 am
Apparently Discovery modified the powervu encryption since it only listens to audio and does not give an image all the channels belonging to Discovery, the problem is for all the stb only the Cisco stb can open them
Peugeot 207
Post by Peugeot 207 » Sat Nov 13, 2021 1:25 pm
No.
Absolutely no PW modification from Discovery.
There is no anymore VPID sending in stream. So, some boxes who PMT VPID check , have black screens. Other boxes like Hellobox who doesn't VPID check have both: picture and audio.
BUT
If we done transponder rescan, channels without VPID will be stored as radio station of course.
As far as I know , there is not any solution for manually input VPID's on Hellobox.
Maybe somebody knows other solutions.
