User DBTool release
User DBTool release
DBtool is a tool for importing and exporting user program data. With DBtool, you can easily edit satellites and programs.
The latest software supports this feature.
Supports list:Hellobox8,Hellobox6
System:Win10,win7
Plz download all.
System:Win10,win7
Plz download all.
- DBtool.part1.rar
- (5 MiB) Downloaded 10481 times
- DBtool.part2.rar
- (3.14 MiB) Downloaded 12304 times
Re: User DBTool release
Hello Thank you very much for the DBTool
Excellent Job!!!
Please add Audio_pid , Audio_type (Mpeg, AC3, AAC etc) and Service ID into the Edit Program feature for next release?
How to identify Video Type 0 and 1?? Video 0? Video 1? How to identy SD/HD
Excellent Job!!!
Hi, I can't install DBTool on a Windows 7 32 Bit system, when I open the archive it gives me an error.
how to use DB Tool?
Plz download again,try again . Update support win7Cluster.One wrote: ↑Tue Nov 30, 2021 12:17 pmHi, I can't install DBTool on a Windows 7 32 Bit system, when I open the archive it gives me an error.
USB upgrade- export channel, u will get a file(hellobox8_channel.ddf),Then use this tool to edit or add programs.
Ok,You can try using the copy function,then you change other values.(The values you refer to are saved by default)
Hello Fenddick, it' s impossible unzip part 1 because Windows Defender finds a virus and blocks the installationfenddick wrote: ↑Wed Dec 01, 2021 6:07 amPlz download again,try again . Update support win7Cluster.One wrote: ↑Tue Nov 30, 2021 12:17 pmHi, I can't install DBTool on a Windows 7 32 Bit system, when I open the archive it gives me an error.
This is normal, please don't worry. You can temporarily turn off Windows Defender to decompress again. After successful decompression, you can add DBtool to the excluded scan file in the real-time scan of Windows Defender. In this way, even if you open Windows Defender again, you will not be notified that there is a virus.pinolo wrote: ↑Wed Dec 01, 2021 6:33 amHello Fenddick, it' s impossible unzip part 1 because Windows Defender finds a virus and blocks the installationfenddick wrote: ↑Wed Dec 01, 2021 6:07 amPlz download again,try again . Update support win7Cluster.One wrote: ↑Tue Nov 30, 2021 12:17 pmHi, I can't install DBTool on a Windows 7 32 Bit system, when I open the archive it gives me an error.
Thanks Friend, but isn' t normal: I' ll wait until the bug is deleted to be able to download the Editor.cheng wrote: ↑Wed Dec 01, 2021 8:33 amThis is normal, please don't worry. You can temporarily turn off Windows Defender to decompress again. After successful decompression, you can add DBtool to the excluded scan file in the real-time scan of Windows Defender. In this way, even if you open Windows Defender again, you will not be notified that there is a virus.
