Hellobox 8 firmware release 20210414A
Post by fenddick » Thu Apr 15, 2021 2:06 am
  • add satellites(46e,51.5e)
  • support biss program without biss CAS indicator 2600
  • fix powervu audio issue
  • fix 57E audio type issue
  • fix cccam bug
  • fix some tp blind scan crash issue
  • add some new satellites in preset
  • update powervu
Hellobox8_20210414.rar
(4.29 MiB) Downloaded 2175 times
Re: Hellobox 8 firmware release 20210414A
Post by Yawwilson » Thu Apr 15, 2021 2:42 am
Thanks!
Post by Garuda_ID » Thu Apr 15, 2021 3:56 am
alangoh
Post by alangoh » Thu Apr 15, 2021 5:14 am
Post by 彩票游戏 » Thu Apr 15, 2021 1:27 pm
New firmware↓
h8-20210414中文固件.zip
(5.13 MiB) Downloaded 1457 times
Post by 彩票游戏 » Thu Apr 15, 2021 1:29 pm
为何要单独屏蔽了88E ST2卫星PLS?
Post by 彩票游戏 » Thu Apr 15, 2021 1:32 pm
请告诉我PLS码在固件里哪个文件夹,谢谢!
Post by edzus1 » Thu Apr 15, 2021 5:16 pm
A question for programmers and also developers.
When will the plurality of errors be fixed that are present in the firmware for Hellobox 8?
I was creating a separate topic in the section about Hellobox 8
here http://www.freedvb.com/viewtopic.php?f=25&t=19128
I don’t see any sense for updating to this new firmware 20210414A Reason: none of the multiple errors that are present in the firmware has not been fixed:
1. PVR is a long record that exceeds more than 4 GB (the recording time is reduced after cutting off the first 4 GB, after the creation of the second video file (continuing the video recording on the second file), the recording time is sharply reduced) This problem on Hellobox 8 firmware is mentioned on the forum from end of August 2019
2. TIMESHIFT does not work with encrypted channels.
This problem on Hellobox 8 firmware has been mentioned on the forum since July 2020
3. Associated with Hellobox 8 NEW version (in standby mode the processor remains under full load)
I myself mentioned this problem on Hellobox 8 NEW firmware on the forum on November 4, 2020, starting with firmware 202001027A
kalmars
Post by kalmars » Sun Apr 18, 2021 2:21 pm
The version does not work with the protocol diseq 1.2, the engine does not listen and jerks or does not turn at all.
the only version that somehow works normally ae diseq 1.2 is 20201027
Arbourboateng
Post by Arbourboateng » Mon Apr 19, 2021 5:37 am
Thanks Mr fenddick for what you and your crew are doing , is there any chance to solve abertis channels on 30w on H8 with possible a new firmware?
