Hellobox 8 firmware release 20200522
Post by fenddick » Fri May 22, 2020 8:29 am
  • Update Youtube&Youporn
Hellobox8_20200522.rar
(4.5 MiB) Downloaded 750 times
Re: Hellobox 8 firmware release 20200522
Post by 彩票游戏 » Fri May 22, 2020 8:30 am
Hellobox 8_2020/05/22_chinese firmware
Chinese firmware also has English menu, welcome to download
h8-0522中文固件.zip
(5.13 MiB) Downloaded 468 times
Post by Garuda_ID » Fri May 22, 2020 8:43 am
Fix 8612 😊
Post by 彩票游戏 » Fri May 22, 2020 11:14 am
oK
pinolo
Post by pinolo » Fri May 22, 2020 3:16 pm
LIVE list disappeared with this update :|
pinolo
Post by pinolo » Fri May 22, 2020 3:28 pm
Isn' t problem to update: LIVE don't work also with the previous version.
pinolo
Post by pinolo » Fri May 22, 2020 4:00 pm
Now LIVE it' ok, but not Youtube :?:
edzus1
Post by edzus1 » Fri May 22, 2020 8:15 pm
There are errors in the programming
1. Time accuracy:
   The watch is in standby mode. In 1 hour, the watch is ten minutes behind; in 11 hours, the watch is already 2 hours behind.
2. From the execution of the timer program.
  Hellobox 8 New may turn on, may not turn on by timer. According to the timer program, the specified channel or the channel that was during the transition to standby mode will turn on. When turning off by the timer, the receiver may turn off or continue to show the same channel or transmit to that channel which was before executing the timer program.
Re: Please help / Hellobox 8 firmware release 20200522
Post by fenddick » Tue May 26, 2020 6:42 am
aab44 wrote:
Tue May 26, 2020 12:20 am
Dear fenddick
After upgrading to firmware release 20200522 by USB
Hellobox 8 (new version) hung after boot and not responding to remote nor device buttons
Is there way to reset device or downgrade to older firmware release 20200320 or 20200410 ?
Please help
Download the old software and rename it to “auto_burn.fac”,then insert it into the STB,restart the STB box until the panel shows FFFF.
Remember to delete this file, otherwise it will be upgraded all the time
edzus1
Post by edzus1 » Thu May 28, 2020 9:01 pm
1. Time accuracy:
About the timer work has already been raised on the forum http://www.freedvb.com/viewtopic.php?f=25&t=18400
The problem is still not fixed.
