Hellobox 8 firmware release 20191031
Post by fenddick » Thu Oct 31, 2019 6:57 am
  • add Live App(free)
  • audio enhanced
Important note:
check software update time in "Mainmenu->Tools->Latest update" before upgrading!
If your current update time is earlier than 20190812, for example 20190725, you should use one of the two methods below to avoid audio problem.
Method 1: Upgrade by using "auto_burn.fac".(your settings/channels will lost by this method)
Method 2: Upgrade this version twice: first USB upgrade the 20191031 version, after the box reboot, USB upgrade the 20191031 vresion again!
If your current update time is later than 20190812, such as 20190814, 20190906, just ignore this note.
Hellobox8_20191031.rar
(4.49 MiB) Downloaded 874 times
Re: Hellobox 8 firmware release 20191031
Post by 彩票游戏 » Thu Oct 31, 2019 3:14 pm
此固件支持88Ku高清吗?
machteck
Post by machteck » Thu Oct 31, 2019 9:23 pm
Well it certainly did not help the audio on my box 8. Yes i loaded it twice 3 times 4 times :?: :?:
Post by 彩票游戏 » Thu Oct 31, 2019 11:43 pm
There is something wrong with this firmware. The Chinese font has been uploaded, but it does not show. The color of the modified menu does not correspond[/img][/img]这个固件有问题,上传了中文字体,不显示,修改的菜单颜色居然不对应
Post by gxu » Fri Nov 01, 2019 12:07 am
What do you expect for audio?
machteck
Post by machteck » Fri Nov 01, 2019 12:31 am
The audio is verry low on like fox network 133W with the 2019 08 14 update it did help a little 20190906 no change 20191031 still no change. Also with the newest update 20191031 it will not find keys. If you remember this is the receiver i am having trouble with moving my c ban dish. Do you think the engineers or software writers would like me to send this receiver back for testing and information purposes, if they would i will send it back if you can get me an address to send it to Thanks.
Post by gxu » Fri Nov 01, 2019 2:04 am
this version support more audio format, such as dd+.
machteck
Post by machteck » Fri Nov 01, 2019 2:24 pm
The audio is good now, by reinstalling the last firmware and took the option no on saving data fresh install. :D
pinolo
Post by pinolo » Fri Nov 01, 2019 5:51 pm
Well done, very thanks ;)
Post by Cluster.One » Fri Nov 01, 2019 5:54 pm
Well done!
Great job of Hellobox engineers, DD+ it's ok now! I'm really happy!
Keep improving this decoder!
Thanks from Italy
