Recover hellobox8
Recover hellobox8
Sir my hellobox 8 only show the boot. Sir how i recover my helllobox 8,sir give me suggestion.
Re: Recover hellobox8
did you use the RS232 method to recover ?Cluster.One wrote: ↑Thu Sep 26, 2019 9:22 amSame thing happened me yesterday!
Procedure described in the link works, Hellobox8 returned to work!
No, autoupgrade method via USB, my H8 was stuck on boot
Hi, me too I cannot boot stuck at red light.Cluster.One wrote: ↑Fri Sep 27, 2019 12:26 amNo, autoupgrade method via USB, my H8 was stuck on boot
can you give me more how you did it and what did you use?
Hi
sorry I do not understand
your Hellobox 8 is locked in this position as picture A
or in this position as picture B ?
mine was locked as picture A and I use autoupgrade method via USB
if instead your H8 shows only red led as picture B, the only solution seems to be RS232 upgrade
- Hellobox red led of death - Copia.JPG (38.89 KiB) Viewed 9372 times
- Hellobox 8 stuck on boot - Copia.png (115.47 KiB) Viewed 9372 times
mine is locked at B and RS232 upgrade doesn't work .Cluster.One wrote: ↑Sat Sep 28, 2019 8:29 amHi
thanks anyway
With me the same case!
Hellobox 8 is a big disappointment!!!
He only worked for 5 hours. I threw the money away! Regards to all.
hi boss,hello box V8 is 88.0e no working.Why ?????
