Hellobox 8 firmware release 20210414A
robicxb
Re: Hellobox 8 firmware release 20210414A
Post by robicxb » Wed Apr 28, 2021 11:40 am
This firmware is full of bugs... cccam/mgcamd not connecting by 3g modem connection
Post by 彩票游戏 » Mon May 03, 2021 10:32 pm
xmh0511 wrote:
Wed Apr 28, 2021 3:14 am
彩票游戏 wrote:
Thu Apr 15, 2021 1:32 pm
-4b45ff830ba28fe7.jpg请告诉我PLS码在固件里哪个文件夹,谢谢!
I admire your patience since I have seen many threads for this issue which you are keeping post. I would say it's almost no possibility to make the engineer adopt your good suggestion. I give up waiting for this function. I have bought another product that is good for customizing inputting `plsn` for the channel of ST-2. That's very wonderful, I never necessary to take the patience to wait for the non-possible things anymore. Moreover, the significance is that that box takes less cost than hello box 8 however supply more functions.
My friend, what type of STB do you buy?
xmh0511
Post by xmh0511 » Thu May 06, 2021 2:16 am
That's GTmedia v8x.
xmh0511
Post by xmh0511 » Thu May 06, 2021 2:20 am
彩票游戏 wrote:
Thu Apr 15, 2021 1:27 pm
New firmware↓h8-20210414中文固件.zip
Appreciate your firmware, It's very wonderful except that the QR-code in the function of DVBfinder cannot be displayed. It's a defect.
bambangy978
Post by bambangy978 » Thu May 06, 2021 7:48 am
I have GTmedia V7SX which is the cheapest one and it has PLSN code input. Actually Hellobox 8 is a flagship (the most expensive model)but without PLSN code input and TS delay. You do the math :D
Post by 彩票游戏 » Mon May 10, 2021 5:21 am
I just added Chinese language to the firmware of the official website and modified the background. Other problems can only be solved by engineers
xmh0511
Post by xmh0511 » Thu May 13, 2021 2:49 am
Nope, I think it's not an issue of the formal firmware. I also flash the newest formal firmware into my stb, the QR-code function is ok. As a contrast, the function in the firmware you published does not work, please check this issue and fix that.
Post by 彩票游戏 » Thu May 13, 2021 1:41 pm
Please map QR code, this feature is rarely used. Add Chinese language and change the background, this function has not been changed.
Technical
Post by Technical » Sun May 23, 2021 2:25 am
Dvbplayer in hellobox 8 freeze (crash software).
After connecting dvbplayer in hellobox 8 the box crashes after opening the satellite settings. After restarting, the box remains freeze there. Correct this problem.
Technical
Post by Technical » Sun May 23, 2021 2:28 am
Dvbplayer in hellobox 8 freeze (crash software). After connecting dvbplayer in hellobox 8 the box crashes after opening the satellite settings. After restarting, the box remains freeze there. Correct this problem.
