Hellobox 8 firmware release 20191031
Re: Hellobox 8 firmware release 20191031
Post by Cluster.One » Wed Nov 06, 2019 10:57 am
dasajay1 wrote:
Wed Nov 06, 2019 6:42 am
I have downloaded only "Hellobox 8 firmware release 20191031" rar file and extract the file by winrar software and showing error. Kindly help me.
Hi,
have you tried another program to extract the file for example:
Code: Select all
 https://www.7-zip.org/
Post by Cluster.One » Wed Nov 06, 2019 11:24 am
Yawwilson wrote:
Mon Nov 04, 2019 12:45 pm
Cluster.One wrote:
Fri Nov 01, 2019 5:54 pm
Well done!
Great job of Hellobox engineers, DD+ it's ok now! I'm really happy!
Keep improving this decoder!
Thanks from Italy
My dear friend you seems to get everything working well for your Hellobox8..can't understand why a lot of complaints or do we have "fakes" (boxes) in the system?...
Would be nice if you could talk about the benefit in your box and recommend it to a lot more people..
Hi,
I really don't know why all these defective boxes... for this reason for now I cannot recommend the purchase
Hellobox 8 is not the perfection, there are various bugs for example timer recordings are unreliable, long lasting manual recordings stop before the program ends... but considering some special featurest in comparison to other boxes, like t2-mi and multistream thats works well, the price is not bad as long as it works...
Post by Cluster.One » Wed Nov 06, 2019 11:48 am
gyanp1989 wrote:
Wed Nov 06, 2019 10:53 am
After update USB device not found
Is it possible that everything goes wrong? I'm sorry for you but your receiver also has something wrong
My Hellobox 8 works normally after update, usb is regularly recognized
regards from Italy
Post by 彩票游戏 » Wed Nov 06, 2019 10:37 pm
Well done!
Thanks from Italy
Hi,
Support multistream signals?
Post by Cluster.One » Thu Nov 07, 2019 12:38 am
Hellobox 8 support multistream signals, other boxes do it but are all more expensive, this is one of several reasons why I bought it
1t's not possible insert PLS code but seems that are not necessary
Post by fenddick » Thu Nov 07, 2019 1:53 am
Plz download again.
Post by 彩票游戏 » Thu Nov 07, 2019 3:55 am
It is a pity that pLs code cannot be entered, we hope it can be added
Post by 彩票游戏 » Thu Nov 07, 2019 3:56 am
Plz download again.
再次下载也是无用
gmjdfzj123
Post by gmjdfzj123 » Mon Mar 09, 2020 1:47 pm
Thu Oct 31, 2019 6:57 am
  • add Live App(free)
  • audio enhanced
Important note:
check software update time in "Mainmenu->Tools->Latest update" before upgrading!
If your current update time is earlier than 20190812, for example 20190725, you should use one of the two methods below to avoid audio problem.
Method 1: Upgrade by using "auto_burn.fac".(your settings/channels will lost by this method)
Method 2: Upgrade this version twice: first USB upgrade the 20191031 version, after the box reboot, USB upgrade the 20191031 vresion again!
If your current update time is later than 20190812, such as 20190814, 20190906, just ignore this note.
Well done, very thanks
T
gmjdfzj123
Post by gmjdfzj123 » Mon Mar 09, 2020 1:57 pm
  • audio enhanced
Important note:
Well done, very thanks !
