take a picture of your screen, it will show usercode and key code on screen,
Hellobox 8 firmware release 20190814
- spencer26
Re: Hellobox 8 firmware release 20190814
There is nothing on the screen except the remote with button 1 in red.
No other numbers.
I dont have a remote so I cant do anything with that as my box arrived without a remote. One is coming.
No other numbers.
- RCU.jpg (328.19 KiB) Viewed 6019 times
thank you, now I have 3 remotes for 1 STB. press the left panel on the STB, not on the remote. need to be explained more clearly
- spencer26
arikurniaone Can you tell me exactly how you made the remote work.
It is very confusing.
Spencer
Spencer
I just tried it with an older coolsat remote, just entered the menu selected the smart rcu held the left arrow button on the receiver for 10 seconds followed the instructions on screen and it worked, they need to add the power button, audio button, and epg selection but it does work well.
- spencer26
You say you entered the menu. Where did you do that.
I just boot the box then I hold left on box for 10 seconds.
I get the RCU on screen.
But it does not respond to any of my remotes. Including Dreambox remote.
Spencer
Spencer
Stay in satellite Optus D1 .. the picture is not stable... The tunner look like not responsive....when this bugs Will fix? Thank's
- Not good
- 15660366743801632292622.jpg (3.53 MiB) Viewed 5987 times
only support NEC protocol remote, if yours is not, not support. if NEC,it will show user code and key code
- spencer26
Found an old NEC remote.
Working. Thanks.
Spencer
Working. Thanks.
Spencer
Thanks for sharing
