Release HelloMerger V1.4
Joey
Post by Joey » Fri Feb 05, 2021 9:38 am
Both support Hellobox CS8001 & GX6605S merge ir panel.
Max support 2 ir on CS8001.
If ir not work,change "User Code Revert"
try again.
HelloMergerV1.4.rar
(5.08 MiB) Downloaded 8181 times
josetoni
Re: Release HelloMerger V1.4
Post by josetoni » Fri Feb 05, 2021 5:12 pm
thanks so much friend
Sumitro Ananda
Post by Sumitro Ananda » Sat Feb 06, 2021 12:30 am
Terima kasih
Post by Garuda_ID » Sat Feb 06, 2021 12:58 am
Good job
broadway
Post by broadway » Mon Feb 15, 2021 7:51 pm
Tried Hello merger v1.4 with cs8001
It works when importing panel buttons
Importing for remote control doesn't work. Tried with and without tick mark(user revert code)
abhaysingh2009
Post by abhaysingh2009 » Sat Feb 20, 2021 1:08 pm
Remote pairing not working panel and leds pairs pls fix this issue.
abhaysingh2009
Post by abhaysingh2009 » Sun Feb 21, 2021 10:41 am
My box has remote codes of 72 bytes each(ir1 and ir2) and Hellobox cs8001 firmware has 128 bytes of remote codes. I think that's the reason why my remote is not pairing through hellomerger 1.4. right now I am using smart rcu to pair a remote but many features like change audio,epg,livetv recording does not work. So developers pls sort out this pairing issue of hellomerger in next release. Thanks for this Hellobox cs8001 firmware Hellobox team.
broadway
Post by broadway » Tue Mar 02, 2021 11:35 am
Yes
Partition sizes of hellobox firmware is different than existing OEM firmwares that's why ir1 editing(remote) is faulty. Ir2 editing(front panel buttons) working properly as far as I know.
joey67
Post by joey67 » Sun Apr 18, 2021 9:13 am
ok
sandeep25
Post by sandeep25 » Sun May 30, 2021 4:26 am
Dear team,
Thanks for nice release...
pls inform how to configure lock signal led & standby led on front panel in cs8001 firmwares.
Thanks in advance
Sandeep
