Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
JoeU
Re: Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Post by JoeU » Sat Jan 30, 2021 6:48 pm
esdhrgl1 wrote:
Wed Jan 27, 2021 5:34 am
BASED ON CONNECTOR POSITION IT SHOULD BE LIKE IN IMAGE ATTACHED AND DEPNDING ON YOUR CONNECTOR TYPE LOOK FOR CONNECTION IN IMAGE.
DO IT ON YOUR OWN RISK . DONT BLAME ME FOR ANYTHING WRONG HAPPENS AS THER IS NO LABELING.STILL YOU CAN CHECK GND WITH CONTINUITY CHECKER.
please help me i am waiting for your reply thanks
esdhrgl1
Post by esdhrgl1 » Sun Jan 31, 2021 6:58 am
hay bro i buy everything but i get this type of error when i try
bootrom error wait for get please check stb uart receive
fail
Do some things
1. Check for ground if it is ground with continuity checker
2 try with yaffs checked
3 If still unable to flash after yaffs checked try toggling tx and rx wire then flash without & with yaffs.
Most important share screenshot of device manager windows with serial com port for confirmation. In your case it seems like com6.
Last try with original dump of box
JoeU
Post by JoeU » Sun Jan 31, 2021 9:34 am
fail
Do some things
what is the problem
aa7590
Post by aa7590 » Sun Jan 31, 2021 12:38 pm
fail
Do some things
i try with original dumb file and also try with yaff and without yaf but it always fail i also disabel window defender.... what is the problem?
what is the problem
B ROTHER CHANGE THE RX WITH DX PIN IN 6605S BOARD MEAD LEFT CHAN GE WITH RIGHT PIN OK
esdhrgl1
Post by esdhrgl1 » Sun Jan 31, 2021 4:29 pm
fail
Do some things
what is the problem
Try downloading rs 232 downloader like ver 1.21 older then yours and run it as administrator.
Try finding ground pin using multimeter if u have!
And about problem you doing something wrong and only you can resolve it because we dont have board . Like you erassed your flash before uploading boot to ram or something like that.
And one thing please upload complete clear image of board high resolution with main ic that
meansn of gx6605s
JoeU
Post by JoeU » Mon Feb 01, 2021 5:26 am
Do some things
what is the problem
meansn of gx6605s
bundle of thanks bro its working software updated ......... with help of yours ♥
josetoni
Post by josetoni » Tue Feb 02, 2021 10:17 pm
please help me.
I tryed to use your software but I could not because I recive the message not support
not support.jpg (65.95 KiB) Viewed 87935 times
gx6605s_dynavision_ir_7601_0629(1).rar
(3.23 MiB) Downloaded 2519 times
Joey
Post by Joey » Wed Feb 03, 2021 1:59 am
please help me.
Merge for you.
Next version will fix it,please wait.
GX6605s_20210129_merged.rar
(3.33 MiB) Downloaded 2740 times
josetoni
Post by josetoni » Wed Feb 03, 2021 2:50 pm
I wait. thanks
josetoni
Post by josetoni » Thu Feb 04, 2021 3:45 am
Thanks for the merge Joey but it does not work properly, the image freezes and does not open the audio
