aa7590 wrote: ↑Mon Jan 25, 2021 3:36 pmbrother for laptop use USB Rs 232 converter female pin
Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Re: Release of Hellobox GX6605S ROM New version & HelloMerger V1.3
Can i install this on my wezone 8080 pro?
if your lead wont connect to the b ox then use this lead
Usb to Rs232 female port switch Serial DB9 9 PIN RS232 FEMALE serial cable PL-2303 serch in google u will se the lead image i think this lead will connect you box to lap top whith GXloader
sorry for too much question....
BASED ON CONNECTOR POSITION IT SHOULD BE LIKE IN IMAGE ATTACHED AND DEPNDING ON YOUR CONNECTOR TYPE LOOK FOR CONNECTION IN IMAGE.
DO IT ON YOUR OWN RISK . DONT BLAME ME FOR ANYTHING WRONG HAPPENS AS THER IS NO LABELING.STILL YOU CAN CHECK GND WITH CONTINUITY CHECKER.
- Screenshot_20210126-210126_WhatsApp.jpg (291.05 KiB) Viewed 116588 times
Brother just change the side pic to each other don't change the center one and it will connect ok this is the main difference of GX 6605s with 1506 g boxes for serial lead method okesdhrgl1 wrote: ↑Wed Jan 27, 2021 5:34 amBASED ON CONNECTOR POSITION IT SHOULD BE LIKE IN IMAGE ATTACHED AND DEPNDING ON YOUR CONNECTOR TYPE LOOK FOR CONNECTION IN IMAGE.
Brother as you can see in image as label on board of gx605s. i made no mistake in image about connection and for 1506t i dont know. i have only 6605s board. I never talked about that board never will. I don't intend to buy that boardaa7590 wrote: ↑Wed Jan 27, 2021 12:23 pmBrother just change the side pic to each other don't change the center one and it will connect ok this is the main difference of GX 6605s with 1506 g boxes for serial lead method okesdhrgl1 wrote: ↑Wed Jan 27, 2021 5:34 amBASED ON CONNECTOR POSITION IT SHOULD BE LIKE IN IMAGE ATTACHED AND DEPNDING ON YOUR CONNECTOR TYPE LOOK FOR CONNECTION IN IMAGE.
- IMG_20210127_235615.jpg (288.88 KiB) Viewed 116563 times
GREAT WORK THANKS FOR UPDATE
FOUND TWO MAJOR ISSUE
1. EPG LANGUAGE NOT SHOWING ONLY BOXES APPEARS
2. SECOND LANGUAGE OPTION SHOULD BE THERE IN LANGUAGE SETTING . HAVING ONE LANGUAGE CREATE ISSUE WITH SOUND WHEN CHANNEL TOGGLED OR CHANGED. A MUTE SOUND RESULTS FOR THAT CHANNEL . YOU HAVE TO SET LANGUAGE ENGLISH AGAIN AND CHANGE CHANNEL FOR UNMUTE THE SOUND OF THAT CHANNEL.
UPDATE NOT LISTED
1. FIX OF TIMEZONE FOR COUNTRIES LIKE IRAN MYANMAR SRILANKA INDIA
2. DVBPLAYER 1.3 FOR WINDOWS WORKING BETTER THEN MOBILE DVB PLAYER VERSION 4.3 FOR THIS WORK YOU SHOLUD TURN ON SATIP FROM SETTOP BOX MENU
Well, i just checked... There's no other language besides English. This will create an issue for channels with multiple audio options.esdhrgl1 wrote: ↑Thu Jan 28, 2021 3:51 pm2. SECOND LANGUAGE OPTION SHOULD BE THERE IN LANGUAGE SETTING . HAVING ONE LANGUAGE CREATE ISSUE WITH SOUND WHEN CHANNEL TOGGLED OR CHANGED. A MUTE SOUND RESULTS FOR THAT CHANNEL . YOU HAVE TO SET LANGUAGE ENGLISH AGAIN AND CHANGE CHANNEL FOR UNMUTE THE SOUND OF THAT CHANNEL.
I am also using the second language option to bypass the audio issue with channels that offers different audio streams.
Setting first audio and second audio language to other than English solves the issue. But if there's no other language different than English, then it will be problem. I hope the next update solves this.
still have a problem with my led display panel indicator.
Here I upload the original firmware
- Tanaka_T21_Merpati_HD_20180119_New.rar
- (3.28 MiB) Downloaded 3539 times
