Waiting New firmware v5 plus 2020
Re: New firmware v5 plus 2020/03/06
Post by car mel » Thu Mar 19, 2020 12:37 pm
car mel wrote:
Mon Mar 16, 2020 5:59 pm
Yawwilson wrote:
Mon Mar 16, 2020 4:06 pm
It seems the Hellobox V5hd is always the first to receive updates... hope engineers are working hard to release the software for V5PLUS.. However,if engineers think it's safe to try this current software (for V5HD) on V5PLUS, someone should let us know...
The picture in first post shows V5plus and Not V5HD. There should be a file for V5 plus 20200306 somewhere.
My comment was also clear. The pics in first post show V5 plus. I don't need to know if the software is V5 or V5 plus. It must be clearly stated when posting. I joined group. Only found HB_V5Plus_SRG NETWORK and auto_burn.fac. You should learn the process to install auto burn. Why take time and effort to created a software only to change date & version???
SAM I 10'- Dreambox DM800HDse-Hellobox-GTMedia
Post by Yawwilson » Thu Mar 19, 2020 3:46 pm
Well, the auto_burn.fac for V5PLUS is also 4mb.... have installed it and it's okay the only drawback for now is only my 3g modem works..my WiFi adapter is not working...I believe the programmer forgot to install the WiFi adapter drivers...
Rem: there are two auto_burn.fac(s) one for V5HD and other for V5PLUS
Post by Yawwilson » Thu Mar 19, 2020 3:59 pm
This software (auto_burn.fac) was programmed with South East Asia in mind..so if you live outside that region you have to delete all channels (only) in factory reset.. but if you do absolute factory reset (ie,all), then you will have to figure out where to change the language back to English.
which could give some of us some headache!
Post by Yawwilson » Thu Mar 19, 2020 4:09 pm
Well, now, to the Hello box engineers, I do humbly suggest that in releasing a new software, they should incorporate all that is in this auto_burn.fac (software)..
TomTumb
Post by TomTumb » Fri Mar 20, 2020 4:41 pm
Link pls
Post by car mel » Sat Mar 21, 2020 2:24 pm
Now that people is using the auto_burn.fac resulting on wifi connection problems, it is necesary to released an official new update as soon as posible fixing the problem and adding features as new V5HD released: Update Youtube & Support for new 3G Dongle(D-Link)
imransikn
Post by imransikn » Thu Apr 09, 2020 9:23 am
After above auto burn flash my box is not startup , nothing display shows in box it's not power up
harjeetsingh
Re: Waiting New firmware v5 plus 2020
Post by harjeetsingh » Thu Apr 09, 2020 3:08 pm
Plz give me v5plus new softwer link ..thanks
