Hellobox V5 Plus firmware release 20191109A
Adil
Re: Hellobox V5 Plus firmware release 20191109A
Post by Adil » Sat Dec 07, 2019 4:48 am
My boss auto bisskey not funtion
[email protected]
Post by [email protected] » Sat Dec 07, 2019 3:32 pm
Pionex2020 wrote:
Mon Dec 02, 2019 12:58 pm
Thanks for fixing the AC3 lockup issue.
You need to fix the low volume issue.
True the decoder has the lowest volume compared to when I switch to my other decoder.
dhk
Post by dhk » Sun Dec 08, 2019 3:37 am
dhk wrote:
Fri Dec 06, 2019 5:55 am
gxu wrote:
Fri Dec 06, 2019 1:56 am
If your scam has already actived before, do not worry, nothing to do with it.
What if I have a new box and don't intend to activate scam+ immediately ( may be after the expiry of scam+ on the older box I use)?
Then can I just upgrade sw on the new box and activate it later?
@ gxu & admins
Could you please clarify about new unsure boxes scam+ activation?
Restey
Post by Restey » Sun Dec 08, 2019 10:23 am
Doesn't work powervu key @ discovery network and sony network @ intelsat,20 and 17,
Any update pls,
Post by gxu » Mon Dec 09, 2019 2:22 am
@ gxu & admins
Don't worry about it, we want to make it better not worse.
It only matters the first activation. You can not active it with old software now, the only way is to active with the new software.
So if you did not active the box, nothing to worry about.
Restey
Post by Restey » Mon Dec 09, 2019 4:59 am
Not updated powervu key , same as old software,
Why ? doesn't work sony and discover network @ intelset 20 ch,
dhk
Post by dhk » Mon Dec 09, 2019 7:21 am
@ gxu & admins
Great thanks 👍
Will123
Post by Will123 » Mon Dec 09, 2019 4:46 pm
I find some of these posts confusing. Bottom line: does this update work? Will it cause issues I don't have?
7 1/2 ' mesh dish, Titanium C1 PLL Titanium ASC1 Dish Positioner Freesat V 8 Super Hellobox V5 Plus
Skhan
Post by Skhan » Tue Dec 10, 2019 4:16 am
Hallobox v5 Plus new software update link sand please sir
Post by Yawwilson » Fri Dec 13, 2019 5:58 am
My dear Mod(fenddick) and engineers, a couple of multi stream channels on 28east(Africa beam) are not scanning in with this latest software... Can it be fixed?
