Post
by fenddick » Mon Dec 02, 2019 1:59 am
Release notes:
- add scam qrcode active in Network->Scam+
Warning:
1. backup of your channel/setting information, this version may lost your data.
2. Due to the scam server upgrade, you must use this new software to active the scam!
The old scam active will not work soon. It does not affect the scam that already actived.
- k5_ddr2_vision_cstm_hbplus_20191109A.rar
- (4.03 MiB) Downloaded 1128 times
Samuel2019
Post
by Samuel2019 » Mon Dec 02, 2019 6:17 am
Thanks for the software, can someone explain to me what is t2mi, thanks.
Pionex2020
Post
by Pionex2020 » Mon Dec 02, 2019 12:58 pm
Thanks for fixing the AC3 lockup issue.
You need to fix the low volume issue.
sarkar
Post
by sarkar » Tue Dec 03, 2019 7:54 am
Dear Experts.
First of all thanks for making update and sharing on website.
I updated my Hellobox V5 plus last night.
Before update i save my channels by pressing green button.
Then make update.
After reboot i try to make upload my channel list.
But that file shows unsupported.
Than i again make blind search in all satellites.
3G modem is not exist shows same as before after stop power by remote. Need power off from main source for re start.
You p**n list not downloading same as previous version .
Videocon is running or not i Didn’t check.
Biss key autoroll but lnitially it takes more time.
Channel opening is firster than before.
That's very nice.
Dish tv little freezing compaird to sky net.
Post
by Yawwilson » Tue Dec 03, 2019 1:07 pm
fenddick wrote: ↑Mon Dec 02, 2019 1:59 am
Release notes:
Warning:
Thanks! Appreciate the hard work!!!
Balendu Sharma
Post
by Balendu Sharma » Thu Dec 05, 2019 5:11 am
Sir please explain more details of this explanation ". Due to the scam server upgrade, you must use this new software to active the scam!
The old scam active will not work soon. It does not affect the scam that already active"
Will it affect my Scam it has more than 11 months expiry date, will QR code be needed to active the scam after the update.
Will it support Russian Packages in T2-MI PLP 1/2 like channels in Express AM7 at 40E C Band
Post
by gxu » Fri Dec 06, 2019 1:56 am
Balendu Sharma wrote: ↑Thu Dec 05, 2019 5:11 am
If your scam has already actived before, do not worry, nothing to do with it.
dhk
Post
by dhk » Fri Dec 06, 2019 5:55 am
gxu wrote: ↑Fri Dec 06, 2019 1:56 am
What if I have a new box and don't intend to activate scam+ immediately ( may be after the expiry of scam+ on the older box I use)?
Then can I just upgrade sw on the new box and activate it later?
Balendu Sharma
Post
by Balendu Sharma » Fri Dec 06, 2019 7:18 am
Thanks for the reply, what about T2 MI, will it support Russian package in T2 MI PLP or is it just for terrestrial transmission support
