Recover hellobox8
Bahar
Recover hellobox8
Post by Bahar » Fri Sep 20, 2019 4:14 am
Sir my hellobox 8 only show the boot. Sir how i recover my helllobox 8,sir give me suggestion.
Re: Recover hellobox8
Post by car mel » Fri Sep 20, 2019 4:38 pm
viewtopic.php?f=25&t=14226
Post by Cluster.One » Thu Sep 26, 2019 9:22 am
Same thing happened me yesterday!
Procedure described in the link works, Hellobox8 returned to work!
[email protected]
Post by [email protected] » Thu Sep 26, 2019 5:02 pm
did you use the RS232 method to recover ?
Post by Cluster.One » Fri Sep 27, 2019 12:26 am
No, autoupgrade method via USB, my H8 was stuck on boot
[email protected]
Post by [email protected] » Sat Sep 28, 2019 12:07 am
Hi, me too I cannot boot stuck at red light.
can you give me more how you did it and what did you use?
Post by Cluster.One » Sat Sep 28, 2019 8:29 am
Hi
sorry I do not understand
your Hellobox 8 is locked in this position as picture A
or in this position as picture B ?
mine was locked as picture A and I use autoupgrade method via USB
if instead your H8 shows only red led as picture B, the only solution seems to be RS232 upgrade
Hellobox red led of death - Copia.JPG (38.89 KiB) Viewed 9378 times
Hellobox 8 stuck on boot - Copia.png (115.47 KiB) Viewed 9378 times
[email protected]
Post by [email protected] » Sat Sep 28, 2019 8:11 pm
Hi
mine is locked at B and RS232 upgrade doesn't work .
thanks anyway
Ady007
Post by Ady007 » Sun Sep 29, 2019 5:02 pm
With me the same case!
Hellobox 8 is a big disappointment!!!
He only worked for 5 hours. I threw the money away! Regards to all.
[email protected]
Post by [email protected] » Tue Oct 01, 2019 6:56 am
hi boss,hello box V8 is 88.0e no working.Why ?????
