Hellobox 8 firmware release 20190814
Re: Hellobox 8 firmware release 20190814
Post by gxu » Fri Aug 16, 2019 7:04 am
spencer26 wrote:
Thu Aug 15, 2019 12:57 pm
Followed instructions.
Left Arrow on box for 10 seconds brought up the remote on the screen.
Hit 1 1 1
No response
Hit 0 0 0
No Response from 3 different remotes.
Spencer
take a picture of your screen, it will show usercode and key code on screen,
spencer26
Post by spencer26 » Fri Aug 16, 2019 7:54 am
There is nothing on the screen except the remote with button 1 in red.
No other numbers.
I dont have a remote so I cant do anything with that as my box arrived without a remote. One is coming.
arikurniaone
Post by arikurniaone » Fri Aug 16, 2019 10:47 am
thank you, now I have 3 remotes for 1 STB. press the left panel on the STB, not on the remote. need to be explained more clearly
spencer26
Post by spencer26 » Fri Aug 16, 2019 2:43 pm
arikurniaone Can you tell me exactly how you made the remote work.
It is very confusing.
Spencer
magicman
Post by magicman » Fri Aug 16, 2019 6:36 pm
Spencer
I just tried it with an older coolsat remote, just entered the menu selected the smart rcu held the left arrow button on the receiver for 10 seconds followed the instructions on screen and it worked, they need to add the power button, audio button, and epg selection but it does work well.
spencer26
Post by spencer26 » Fri Aug 16, 2019 11:38 pm
You say you entered the menu. Where did you do that.
I just boot the box then I hold left on box for 10 seconds.
I get the RCU on screen.
But it does not respond to any of my remotes. Including Dreambox remote.
Spencer
Apayodiq
Post by Apayodiq » Sat Aug 17, 2019 10:12 am
Stay in satellite Optus D1 .. the picture is not stable... The tunner look like not responsive....when this bugs Will fix? Thank's
Not good
Post by gxu » Sun Aug 18, 2019 1:37 pm
Spencer
only support NEC protocol remote, if yours is not, not support. if NEC,it will show user code and key code
spencer26
Post by spencer26 » Mon Aug 19, 2019 1:00 am
Found an old NEC remote.
Working. Thanks.
Spencer
Selvakumar
Post by Selvakumar » Mon Aug 19, 2019 2:35 am
Thanks for sharing
