Bluetooth connection problem
Posted: Fri Nov 22, 2019 7:40 pm
by ratoncrispin
Hi.
i have bluetooth connection problems.
i have a band c dish. when i connect in my room have connection, and signal. When i on the roof, no bluetooth connection, never connect to find signal. Same usb cable, same AC adapter.
how can i fix it?
Re: Bluetooth connection problem
Posted: Mon Dec 02, 2019 4:23 am
by Anubis86
I think Hellobox Smart s2 is an abandonware for the developer as there is no reply from them.
I have also posted my several problems related to this box after latest update but no reply from them.
Posted: Wed Dec 04, 2019 1:49 am
This is a bit complicated. First you need a flash burner, and then you need to remove the flash from the stb,Finally burn firmware in it.
