Subtitle Bug
Subtitle Bug
Please fix this bug, subtitle on ZEE TV, ZEE Cinema and ZING at Eutelsat 16E is not showing when u press the subtitle key on the remote control, the channels have the subtitle provision... Hellobox 8 works very fine it shows the subtitle on those channels..
- IMG_20210408_173126_477.jpg (3.32 MiB) Viewed 2112 times
- IMG_20210408_173121_056.jpg (2.79 MiB) Viewed 2112 times
- IMG_20210408_173043_618.jpg (3.43 MiB) Viewed 2112 times
Re: Subtitle Bug
Pls record a stream and send it to me(3-5mis)-----Media Center-TS recordUmufele Fele wrote: ↑Thu Apr 08, 2021 3:35 pmPlease fix this bug, subtitle on ZEE TV, ZEE Cinema and ZING at Eutelsat 16E is not showing when u press the subtitle key on the remote control, the channels have the subtitle provision... Hellobox 8 works very fine it shows the subtitle on those channels..
Re: Subtitle Bug
Okay I will do sofenddick wrote: ↑Wed Apr 14, 2021 1:53 amPls record a stream and send it to me(3-5mis)-----Media Center-TS recordUmufele Fele wrote: ↑Thu Apr 08, 2021 3:35 pmPlease fix this bug, subtitle on ZEE TV, ZEE Cinema and ZING at Eutelsat 16E is not showing when u press the subtitle key on the remote control, the channels have the subtitle provision... Hellobox 8 works very fine it shows the subtitle on those channels..
