Hellobox V5 firmware test 20201021
Post by gxu » Wed Oct 21, 2020 10:03 am
A test firmware for 108E freezing issue
  • Add ts delay function in Mainmenu->expansion->TS delay
A ts delay function is added in this version, and here is some introduction about TS delay
1. TS delay Mode "Off": nothing different with normal channel play
2.TS delay Mode "ON": all channel will be delayed, and the delay time is the value of Item "Time" in this menu
3.TS delay Mode "Auto": default mode, the freezing will be monitored automatically when playing channel. If some times of freezing is detected, it will pop a dialog with "Do you want to optimize freezing?", then select "YES" to optimize.
if you are using 108E sharing, please help to check this version. Any feedback is welcome.
Thanks,
k5_ddr2_classical_cstm_hellobox_20201021C.rar
(3.26 MiB) Downloaded 6779 times
Re: Hellobox V5 firmware test 20201021
Post by Garuda_ID » Wed Oct 21, 2020 1:02 pm
Thank you sir
Sumitro Ananda
Post by Sumitro Ananda » Wed Oct 21, 2020 1:42 pm
Terima kasih informasinya
Zaw Zaw Aung
Post by Zaw Zaw Aung » Fri Oct 23, 2020 6:35 am
Thank a lot .
TS ON /500 is ok .
That is smooth seeing to audio & video
rehan
Post by rehan » Fri Oct 23, 2020 11:38 am
thank You so much , huge respect and love for your hardwork and continuous support
rehan
Post by rehan » Fri Oct 23, 2020 11:55 am
Tested , there is no freeze at all , channels working like free to air 😍
u zaw gyi
Post by u zaw gyi » Mon Oct 26, 2020 7:20 am
Please update firmware for v5 plus.
Asiasat 7 power vu not open. Also 68e and 66e fixed it. Please.
unniozhur
Post by unniozhur » Thu Oct 29, 2020 7:12 pm
Thanks,
Great work ,99% success.Thanks brother.....
suzon1986
Post by suzon1986 » Fri Oct 30, 2020 3:56 am
thanks mate
HELLO BOX 8
HELLO BOX 6
KOS GSKY V5
K5S Modern
FREESAT V7 COMBO
FREESAT V8 PRO 2
GTC 4K
GX6605S
TIGER T8 V2
STARSAT EXTREME 2000
DIGISAT 3232 UHD
OPEN BOX Z5
SOLID 6321 HEVC
ADLINK 9999 HD
DC BBS-1
railroad
Post by railroad » Sat Nov 07, 2020 2:13 am
what about north amreican sats how do we get a list for these ?????
